I've been lurking here on MUD for months researching...and researching...and researching...before finally pulling the trigger on this beauty!
I flew out to Chicago to pick her up and took her immediately on a 16-hour marathon solo road trip back to Golden, CO. (a proper name is still forthcoming...these things have to come organically). Only a few things happened on the trip home - the snorkel flew off at some point, I lost a windshield wiper, and the front piece of chrome molding fell off right as I was about to pull over to reattach it.
Some quick facts:
Some quick facts:
- 24V 12H-T w/ only 111k mi (180k km)on the odometer.
- h55f transmission
- Brown, High roof w/ original decals (4E8)
- Trim: FM42
- Body code P-HJ61V-MMZX
- 2" lift running on brand new 33" Firestone Destination A/T tires
- 2 brand new batteries
- Drivers side window not working. FIXED - just a loose connection.
- Sunroof not working - sounds like its getting power, but won't move.
- Dashboard cracks (who cares - for now)
- Radio not working, Antenna broken.
- Front engine exhaust pipe rusty w/ small hole
- Driving on the right side of the car is weird. Mainly lane position, and accidentally switching on wipers when I wanted turn signals and vice versa.
- Tachometer not working - turbo lights work, appears to have continuity from sensor in h55f bellhousing. Blown gauge? doing more diagnosis soon.
- When driving for a long period of time (2+hrs), power will slowly decrease. Separate post forthcoming on how to diagnose this issue.
- Tailgate lock stuck in unlocked position. Will not turn. Blasted w/ WD-40 & brakleen, no difference. Plan to take to a locksmith unless anyone has any other suggestions? Mechanism appears to be intact from inside the hatch panel.
- Can be a little sluggish to start on cold mornings without a little bit of encouragement from the gas pedal. It has been ~30F outside on several occasions, and I haven't seen the glowscreen light come on. Need to look into this - not sure if light is burnt out, relay is blown, or if it's just not cold enough out to warrant the glows coming on. It blows a little bit of white smoke right from startup to ~15-20 seconds afterwards, then goes back to normal
- Fix the damn tach - In progress.
- Install new radio & step-down converter for the cig lighter plug & tow harness.
- Print a new face for the speedo so I actually know how fast I'm going without having to do math.
- Investigate/fix sunroof malfunction.
- Get the rear hatch fixed.
- Do a full fluid change/flush where applicable.
- Weld on a new exhaust flex pipe and pass emissions
- New front seats - would love heated seats again. Only thing I miss from my old WRX. In addition, fabric is juuuust about to tear in the same spot that everyone's seats tear.
- Install full sound-deadening & insulation
- custom-make new carpeting. SOR's is waaay overpriced for something I can do myself with a little bit of time, cardboard, and a friend's industrial tack sewing machine
- considering a smooth bedliner for the cargo area.
- custom build some sexy drawers and a sleeping platform
- weld up some sliders (after learning how to properly weld)
