Bad emissions report card
love2fly
Flying the Mountains of the NW
Well the old 1982 FJ45 all stock from Australia (no USA emissions) failed the emissions CO% test today with this bad report card.
Never failed before that's why it was kind of a shock.
Actually I am hoping it is not to serious but I wanted to post my report card incase my next attempt fails for sometime to work from.
I set the mixture a full half turn down to the lean side using an RPM gauge while observing for needle drop, then turned rich just by a hair. Runs pretty good at 650 idle. The exhaust pipe smells clean without that rich smell. Allowed 1.2 on idle and the 2500 RPM 0.313 over on idle and 0.58 on the high side RPM.
Will give it a try on Monday.
Any suggestions welcome before hand.
for how long did you warm up the engine before you went to the test ?
We didn't get cats/EGR etc on cruisers until into the 100 series
I had an 80- that had issues once for CO2. I ran two bottles of heet with Premium gas and drove it for 20 minutes before I showed up for the test. It passed with margin.
Does this mean the Aussies didn’t have a cat on their late model 40s?
:rofl:
US had it's own version of emissions on the FJ40 (only model we got after 1967) from the mid seventies on. Probably one of the reasons why Toyota phased out the FJ40 in 1983 and never imported the 70 series. If the Land Cruiser wasn't the model Toyota used to get a foot hold in the US would have probably dropped it completely. Instead turned into a over equipped luxury flagship for the brand.
Warmed up for around 45 minutes, definitely hot. Non ethanol fuel. I received a state letter from the Air Quality Board giving me the okay to have the rig tested without the required US emissions equipment ( Cat, air pump, so on) as long as it would pass the test without the equipment.
This is a NSW truck and as AussieHJCrurza states did not have much in the way of emissions back then compared too what the US was requiring.
I read an interesting article years ago on what the US was requiring Japan (Toyota) to do in regards to emissions almost yearly on the FJ40/45s engines witch was driving up production coasts and hindering the exporting and driving up the sticker price along with Ford, Chevy, Dodge and others lobbing against Toyota and others (with the young EPA) on issues to were Toyota pretty much focused on other countries for the sales of the Landcruiser. This was a completely different time in the US auto industry, were a lot of back stabbing for the off road 4x4 truck (now the SUV market) control was at its peak.
Politics - :meh:
If you have an AIR pump, be sure it's working (putting out a decent volume of air), and in any case, put in several gallons of E-85 or several bottles of Heet on a nearly-empty gas tank. You want a lot of oxygenates in there to clean this up.
Unexpected but it fail again today. Even the gas cap failed and is a couple of days old (new). CO2% dropped a hair, O2% went up, HC went up, and CO% went down a hair. All I did on this visit was leaned the mixture to max? Pretty wild. Federal standards testing.
I think the information in the link you posted referring to the CO%, some unburnt fuel as float level and anything relating to that could be it. I was still a little confused on the gas cap failing being it is brand new.
Thanks for the link
Well I am going to admit it and blame it on brain memory loss(or old age). I decided to remove the Carb to inspect and maybe adjust the float, as soon as I remove the air cleaner it hit me, I had replaced the old carb around June of this year with a new Carb. This carb is a non US type ( as is the old one) but unlike my old carb only has one vacuum port on the base compared to two on my old Carb. Other than that I have no idea what the jet size is but the float was dead on. So with that said I decided to put my old Carb back on to see what takes place on the next test. Again my brain is not thinking as when I removed the new Carb I saw that the isolation block that is found between the manifold and carb body had no gaskets, just the block. Okay I have to ask should there be one or maybes two gaskets on the isolation block for sealing?
I have what looked like oil contaminated fuel wetness in areas on the blocks surface (top/bottom) like it was sucking into the thin space between the block and carb due to the vacuum. Not real bad but enough to make me a bit concerned about gaskets.
This is a 1982 2F. The old carb just purrs without any problems and the float is also dead on. Never failed a test with this carb lets see how it does.
Thanks
I do at least 45 minutes for warm-up before I drive into the AZ emissions station
in some years, when the gas tank level was appropriate for using the product, I also used "guaranteed to pass" - available at O'Reilly's and other autopart stores - gotta follow their instructions completely, or you just blow the $15
CRC
Thanks
can't you just cut a gasket yourself from gasket paper or cork ?
When I look at the block closer it shows that there is no real gasket, it is what looks to be one but it is part of the block itself. I used a thin amount of what we use in Aviation on fuel tank fuel senders, a non Harding fuel resistant sealer to help in sealing the carb when mounted and making sure it does not restrict any holes or ports. I used a small machinist ruler to check the blocks surface and it shows to be just a tad bit not so level but usable with the sealer. After 38 years (after tomorrow new year) I am surprised it is in fair condition. I am also taking into account that I have shortened the exhaust run from exiting the rear of the truck to were the new muffler is right under the drivers seat on the underside with the tip of the exhaust exiting just behind the cab. Such a short run maybe not helping in dissipating/burning off the gases as would a long run exhaust, this is just a hypothetical guess.
I will check into the snake oil product you show not big on it but I do what to get this emissions test over without mudding up the results with chemicals. Thanks
The Saga continues - Failed again. All items super adjusted and set and drove for 23 mile and failed.
This time I went to a different emissions test station, more in tune to the customer than just a guy paying the cost of emissions. This guy said it has a low RPM rumble or a pop or miss than at idle and high RPM, he thinks it is more in the electric than fuel. Also said he has a scope and for a few buck the can check the system and hopefully pin point the fault and adjust before the test.
So I started with the spark plugs at home as they do tell a story of the engine and mine when removed have me a bit confused.
I can not find on the web a troubleshooting of spark plugs that resemble mine in color. As the picture shows most all have a rust red color with some dark areas. One plug looks like crap and these plugs have only 500 miles on them. Not sure if the rust is a by-product of Ethanol fuel but I use no ethanol fuel almost 90% of the time. Anyway I am sure that the fouled looking plug and maybe one other is giving me a high RPM (2500 rpm) miss on the test. That maybe just enough to make the numbers so close but fail.
Will try again in a day or so. I now have 28 days to get it fixed or loose my plates.
Has in the last year
new coil
new Dizzy
new plug wires
new carb
new air filter
Thanks
r
