For your injectors, put in 2 cans of 44K. Drive it like you stole it, let it sit over night, and drive it like you stole it again. I typically do it with about 1/4 tank. It does magic stuff.
It was Denso. NGK/NTK might be ok but there are limited reports, and the 93/94 sensors are different from the 3fe sensors or the obd2 sensors. And different from 'universal' replacement parts. The denso kit is more than $200 which is madness considering they are narrow-band.
Fwiw my 94 replacements in the Toyota kit were NGK. Forum wisdom definitely recommends using the Toyota parts in this case. If $200 is a sensitive amount I would get the injectors serviced first though, because it likely will make some difference, and is a good PM. By contrast the o2 sensors will either make a huge difference or virtually none, and will be a tough slog to do.Apparently NGK was an OEM supplier for 94 as well:
O2 Sensor - OEM vs Denso?
I'm still getting the feel for my mileage and recently did some testing for MPG and ride at different tire pressures. I'm running 285/75R16 load range D mud tires(generic that were on the vehicle when I bought it). The best ride was at 32psi, however bumping up from 35psi to 40psi made a 1-2mpg average increase in mileage. I also noticed the vehicle maintained speed better with the higher tire pressure. The tires have 44K miles on them with 1/3 tread left but will be replace soon.I've done a pretty extensive overhaul of maintenance items on my '93 (including cleaning the injectors, air filter, plugs, etc) and am UP to ~12mpg mixed driving (started at ~11mpg before all the maintenance work). And I have a LIGHT foot on the pedal. No extra weight, no towing, no crazy burn-outs.
I figure mileage is the trade-off for not having to deal with OBDII
296k & 33" BFG KM2's @ 35 psi.
Hell I'm happy to get 10mpg anymore. All those claiming 13.5-15 with stock gearing and oversized tires need to get a speedo recalibration because your MPG's are off your calculating off an incorrect odometer reading, I thought I was getting better fuel economy than I was too until I installed the yellowbox and realized I wasn't driving anywhere near the distance I thought I was. @LS1FJ40 the EGR code is likely causing it a little worse consumption but O2 sensors on older cars of the 90's were scheduled for change most of the time around every 75k miles even newer cars it's recommended before 105k miles and if the O2 sensors aren't working you're losing fuel economy. I would ensure your Plugs are replaced, your O2 sensors are replaced and your cats aren't plugged and see how it fairs from there. An ECU reset (not code erase) would be wise after your O2 and plugs. Then drive around as you normally would for a few days. Then on the next tank compare fuel economy.
ON a recent 190 mile trip of mixed highway and offroading I averaged 14.01mpg based on fill up and odometer mileage which was under what I actually drove due to the stock gears and 285/75R16 tires. Stock gears plus larger tires means per revolution you are traveling further. My actual speed is ~2.5mph higher then what is read. FYI, most stock vehicles sold are designed to read higher than actual speed and distance. Motorcycles are much worse.Hell I'm happy to get 10mpg anymore. All those claiming 13.5-15 with stock gearing and oversized tires need to get a speedo recalibration because your MPG's are off your calculating off an incorrect odometer reading, I thought I was getting better fuel economy than I was too until I installed the yellowbox and realized I wasn't driving anywhere near the distance I thought I was. @LS1FJ40 the EGR code is likely causing it a little worse consumption but O2 sensors on older cars of the 90's were scheduled for change most of the time around every 75k miles even newer cars it's recommended before 105k miles and if the O2 sensors aren't working you're losing fuel economy. I would ensure your Plugs are replaced, your O2 sensors are replaced and your cats aren't plugged and see how it fairs from there. An ECU reset (not code erase) would be wise after your O2 and plugs. Then drive around as you normally would for a few days. Then on the next tank compare fuel economy.
I have always used OEM O2 sensors for both the 91 and 97. At one point I was looking into aftermarket, but I never like to go down that road as it tends to leave a bad taste in my mouth.It was sluggish prior to the EGR Delete. Haven't noticed any discernible difference after the delete.
When I deleted the EGR on my 92 3FE I immediately noticed a difference in the seat of the pants.
I am assuming he O2 sensors are original. Exhaust is all original. I will call the dealer tomorrow to find out about the O2 sensors. And run it by my muffler shop to have them back flow test (or whatever it is they do) the cats. They did this on my 92 when I replaced the O2 sensors. I picked up my O2 sensors from a company that @jonheld recommended. Not sure if they carry the sensors for the 93-94 model. Jon what was the name of that company?
Something is not calibrated right. No way you are averaging 18.5 mpg on a consistent basis.![]()
97 cruiser on 255x85's with roof rack,sliders dual batteries, drawer system and rear tire carrier,also has a yellow box speedo correction...
55-60 mph, got me this...300k miles on motor...
Tire pressure of 50psi
4:10 gears
I have used www.discountconverter.com for replacement downpipes/cats on the 91 with very good results and they carry direct fit O2 sensors as well, but I have never used them.
When I did the custom exhaust on the Lexus I used the Magnaflow downpipe/cat and new OEM O2s.
A seized fan clutch will cause additional drag on the motor and not allow the engine to reach NOT which can decrease mileage and overall performance.
Was the fuel pump pre-filter and inline filter changed or still original? This is on my list and sitting in my parts box.
Those are 100-150K mile maintenance items IMO. I looked at the inline filter the other day. Didn't look too horrible.I have not replaced the pre-filter or inline filter yet. I guarantee they are original. I've heard the inline filter is a PITA! But don't know.
That is my thought...
