- Joined
- Aug 12, 2007
- Threads
- 963
- Messages
- 19,508
Hey guys,
Got an update and some questions, forgive my long windedness in the second half of this post but its mainly to provide context for people in the future, and to let you guys know where I'm at mentally. I really just have no clue how to gauge how much longer it could take and am out of time. The solo trial and error process really does not seem to be feasible esp. if its your only vehicle. Reality is really setting in.....:
First half: technical questions:
I Posted my current undertaking here, its' about the ICS and causing stumbling: Sanity check before adjusting idle & mixture - https://forum.ih8mud.com/threads/sanity-check-before-adjusting-idle-mixture.1324047/
My stumbling issues are persisting and don't appear to be a vacuum leak. Could a not re curved dizzy be a cause? Spark gap? ignition coil? can anything be discerned from this video of my gauge reading so I don't have to chase rabbit holes for another 1-3 months?
(Gauge reading was taken when the timing was heavily advanced to keep it running. At 7 degrees advanced it stumbles even more.)
This is what my vacuum gauge reading looks like as of now. I'm thinking i have a multitide of potential issues as the gauge is wobbly as well as hunting between numbers, and low. Google is worthless for diagnosing and not sure if anyone can help pinpoint if its a valve issue or not ( I rather not recheck timing for the 8th time, and if it truly is a valve problem would a compression check be a more sure fire way of telling?)
Working on the beast more tomorrow but I've reached the point where sinking 12 hours into learning about something that may be a quick conversation over the phone isn't ideal. Wish there were more guys in my town that knew these rigs! Would love over-the-phone help if possible on the electrical diagnosing as its very foreign to me and Im working on the ICS with an aftermarket solenoid.
Second half: the human element:
I'm just now realizing that vacuum can be low for a lot more reasons than just an intake leak/etc, and i have limited time to go through a long checklist, so any advice on where to start based on the vacuum gauge video I took would be helpful (if possible). I can't just throw parts at it either ie: Jim C carb, new dizzy, etc. unless I know within reasonable doubt that that's the problem. A lot of my current plights seem preventable now, but then again, a lot of times you simply have to learn things the hard way, and with cruisers/mechanics for beginners like trial and error seems to be the foundation no matter which way you cut it. (I'm probably 1000-1500 hours in at this point.)
Not trying to complain, just letting future beginners know how and where the project is done matters immensely, this s*** is NOT easy and takes a ridicuous amount of time if you go the trial and error route. I could be 1 hour away from driving it or 100 and I have no way of knowing.
Staying the course, I've trained by brain to enjoy the process rather than end result the best I can. Evne so, I'm seriously considering having it inspected by an actual cruiser tech to know where I stand. Seems like admitting defeat or when I've been told I'm at the 1 yard line, but then again I thought I've been near the end zone for 6 months now. "Wasted time" is just all how you look at it, but does seem like a document or book of all the easy lessons/mistakes that can be preveneted. And to know what to expect if the dice roll doesn't go your way and you're naive like I was. Maybe I will once I'm done with this process. Who knows!
Feeling the weight of a two ton cruiser on my shoulders, hoping some things can be answered over the forum here and I don't have to tow this beast 300 miles to the nearest cruiser shop to get it running properly. ( I can't afford it and don't want to admit defeat either). I just gotta have my vehicle and mental space back. I'm giving myself 2 more weeks to figure it out with all the resources available.
SEE Drive Link for video of my vac gauge at idle
Thanks in advance for answering questions in the first half, and any advice regarding the second half.
Carrying on the hard way,
Dan
hi dan
happy Easter
i have the ICS topic diagnosed , and needed parts solution solved here too ....
the whole fcs and the 2 wire ones on a 2F starting in
below will be my TECH notes on the WHY factor ...
matt
Late Modle 2 Wire Idle / Fuel Cut Solenoid FCS / ICS w/ Correct OEM Factory Profile Sealed Type Electrical Connector Fits ALL 2F Engine Carburetors 1/75-9/87 FJ40 FJ45 FJ55 FJ60 Part # 21060-61060 / 21060-61061 - VintageTEqParts.com
- Late Modle 2 Wire Idle / Fuel Cut Solenoid FCS ICS 2 Wire w/ Correct TOYOTA LAND CRUISER Factory...
vintageteqparts.com
and could hav easily ****ed that up. But the noise didn't really sound like it was coming from there. Just adding for context and in case. Maybe you can hear the noise I hear in the video.
