- Thread starter
- #261
Maybe I should just have them seat me?Tonight more of the same except I’m Currently sitting in my mechanic clothes in a 4 star restaurant waiting for a margarita pizza— last place open and I’m not eating F***ing twinkies
forum.ih8mud.com
I used one on my truck because I wanted to route the PVC back to the intake. You can get a block off plate if you’d rather not have that port open. Either way you need to block the EGR port. Here’s a picture of how it looks. Putting the plate on it makes it look cleaner. This doesn’t bother me, though.Do I need the EGR threaded plug?
No anchovies?
I have fossil evidence that dinosaurs were "petrified" of pineapple pizza. I know several paleontologist who will like back me on this. If you keep pushing, I'll be forced to post bad pictures of Jurassic aged cycads ( like pineapple) and coprolites giving evidence of why T-Rex rid the planet of long necked pineapple pizza eating sauropods. ....and gave us oil for our Land Cruisers. Fair warning!View attachment 3262376
Whoever is responsible for the creation of blasphemous Memes
such as these, we will hunt you down and find you !
Jim sells the rubber caps in his kit.Anyone recommend a carb rebuilder?
I bought a rebuild kit already and was going to have someone help me locally, but not sure if they could Desmog and recurve it etc. Do I need to have something done to Dizzy too?
Already did have items per the desmog guide:
o 3mm: 32 ft (McMaster Carr part #5041K22)
- Plug and Cap set from JimC
- AIR pump Idler Pulley from JimC (or de-vane your smog pump)
- Silicon vacuum tubing (i.e., from McMaster-Carr):
o 6mm: 12 ft (McMaster Carr part #5041K24)
Block-off plate and gasket for EGR "J" pipe:
o Canmakeaplateyourself
o or buy it from MAF (part# 25601)
o or weld a coin of 1” bar stock into the exh manifold EGR opening
o or the J pipe can be cut off, end of tube mashed flat and welded shut.
o Some people recommend RemFlex gaskets, others prefer the OEM graphite gasket.
Rubber or nylon caps for the AIR fittings on the air cleanerThese are included in the Plug/Cap set from JimC
Now imagine what it was like before the internet. I bought my first 40 in 1978 when I was 18. The only mechanical experience I had was rebuilding my Honda CR125 andFolks,
Things are pretty going well over here so far! Engine is almost together and hoping to have this puppy running in a couple weeks.
Figuring out parts situation etc. Ran into a few hiccups after getting the rig here... engine had some rust on it from sitting without wd40. I've mainly been cleaning parts with wire wheel and trying to order dozens of different items from missing head bolts to a new Clutch kit, and helping assemble engine with one of our mechanics here.
My lack of mechanical ability and being able to move the project at the pace I want it is frustrating. I feel semi helpless without supervision from my mechanic co workers. and its hard to know how to study especially because of the following point::::
Usage of online recourses for diagrams, parts numbers, and ordering has been a learning curve enough. From finding part numbers to finding the right diagrams not included in FSMs has been a task in itself. It's honestly hampering my learning as I can't study enough at night because I don't have the means how. Youtube doesn't have much, and my in person time with the mechanic is only so helpful as he basically just does it without explaining it. If I had the proper diagrams in one spot I'd have a chance. I can't tell you how much time I've wasted chasing my own tail trying to find comprehensive diagrams. For instance the one on the right in attachments Ive seen before but can't remember where... Im never sure if the one Im looking at is comprehensive, so knowing if I have all the parts is super difficult. without a mechanic helping I could literally just roll through a project and be missing parts and not know it. its a scary thought and I need a way to have all the diagrams on how things attach to the engine including all parts listed and stop wasting my time as im on a timetable to get this done and out of the shop.
So....
Where the hell can I find fj60 diagrams all in one spot? I've been through Partsouq and all the posted FSM's on the recourses page,
but I'm noticing that the 2f manual and beyond doesn't have everything.
For instance, I thought I had everything I needed to assemble the head by looking at the FSM diagram but then this second one turns up in my old photos and I realize im lacking the proper nut to screw the cylinder head in... the first diagram never had that in there, let alone the part number or what it is even called.
So what's the best way, from your guys experience teaching youselvess, to find out: what all the parts are in full, and what their part numbers are, and if possible what their function is.
Basically I think I'd get a lot more out of this build process if I had someone explain to me all the recourses they used and how they organize them. I don't have the experience yet to just use intuition or logic to know how things go together.
Ive used all the following links without a complete picture, just bits a pieces.. what are more I can use??:
DIAGRAMS Cylinder block for Toyota Land Cruiser FJ60LG - Auto parts - https://toyota-usa.epc-data.com/land_cruiser/fj60lg/3692/engine/1105/11434C/
PartSouq Auto Parts Around the World
We present to your attention our wide range of quality auto parts for many brands of cars. Our genuine parts catalogs and search by part number will help you!partsouq.com
For converting PNC numbers to actual parts numbers Cylinder cover head bolt - https://forum.ih8mud.com/threads/cylinder-cover-head-bolt.1305708/#post-14832770
More FMS Land Cruiser Factory Service Manuals (FSMs) - https://www.cruisercult.com/factory-service-manuals
Hope you all are well, as you can tell im a bit frustrated but just at the end of the day happy my rig is coming together even if It's not as efficient as I'd hoped. I try not to ask for help unless I need it but in this instance I actually need people to spell it out for me :/
Best
Dan
Cool. Thanks allJim sells the rubber caps in his kit.
I would get the block off plate. That way it’s reversible down the road.
I don’t think you’re gonna need that much vacuum line if you’re desmoggong the truck. 90% of that stuff will be gone depending on what components you keep, ie: HAC system. You will need vacuum to the dizzy and from the carb to the manifold I think. Been a minute since I looked at the desmog diagrams.
Get the remflex gasket kit. It’s far superior to the OEM. It’s like two or three times as thick and expands with a few heat cycles to take up any gaps you may have, though you shouldn’t have any if your machine shop did it right. That manifold/intake combo is a real PITA to seal up and the remflex is THE answer to your headaches. You can find them on eBay for cheaper than going directly through the website. I think I paid $45 as opposed to $75 or whatever the remflex site has them listed for.
Send the carb and dizzy to JimC for the desmog set up. I’m not sure if Mark’s off road does dizzy curves, but I know Jim has the equipment to do it.
Watching a build video., Is this the stock water pump? Attempting to Gather all i need to drop her in....Cool. Thanks all
Trying to figure out if I already have the bolts I need for water pump.Watching a build video., Is this the stock water pump? Attempting to Gather all i need to drop her in....
| 9121241040's quanitiy |
That is your thermostat housing you have circled there. The water pump mounts below it. I can’t remember if a new pump comes with mounting hardware or not.Watching a build video., Is this the stock water pump? Attempting to Gather all i need to drop her in....
