Cylinder cover head bolt
Beehanger
winter projects are hell
Idaho
Which bolt goes thru the cylinder head cover?
Got my head on there and bolted down to 92 ft lb etc. Attaching the rest this weak incluing rockers etc, but want to make sure I have the necessary bolts.
I know I don't have enough bolts for the rest of the process of getting this engine in and everyhting attached, and want to order all the bolts I can that I can't get at the local hardware store.
So I'm assuming these top bolts will fall into this category, if there are any other bolts that will be hard to find that come to your brains let me know and Ill get on it.
Im on a timetable here which actually feels good, but sound organization and extra effort are the expense of this!
Beehanger
The aluminum valve cover is clamped down with the special nuts on the threaded studs
Get to know this website linked below and bookmark it.
You can find the part number of every part on your cruiser.
The numbers on the drawings aren’t part numbers (Toyota calls them PNC numbers) except for small bolts. Click on a PNC number on the part you’re interested in and a red popup will appear with the part number.
