Why not open up the clusters and swap the mileage counter from the 93 cluster into the 94 cluster? Once you get in there it's just a few screws and some tabs.
I can't remember, it's been awhile since I had mine open. Solely from memory, maybe. It'll be obvious when you have the back exposed. The pawl on my trip-o-meter broke and I was trying to restore it with some Testor's; didn't work. Must not be ABS plastic.The only reason I considered swapping the gauge clusters is because the first digit of the trip meter currently installed does it rotate.
Can the trio meter alone be swapped? With gps and phone app's, does anyone use that trip meter anymore.
I would leave it as it is. Any vehicle that has been lifted no longer has the correct milage anyway.
A lift has no effect on an odometer. It is all about tire diameter. 33 inch tires fit fine on a stock-height truck and that is roughly a 6 percent error right there. Also some have bothered to correct speedo drive ratios to account for the new tire size.
Marks Adapters in Australia has an electronic adapter that alters the pulses. You can dial it almost perfectly.
Yellowbox. I've been running a plug and play yellowbox V5 for 5 years without issue and I've been able to correct my Speedo to be dead on. Great product and you can get it as either a plug in or wire it in yourself option.Marks Adapters in Australia has an electronic adapter that alters the pulses. You can dial it almost perfectly.
