Advancing the odometer-- How?
I realize that there is a plastic gear inside the transfer case which is driven to generate a signal but from there on it's purely electrical.
I was hoping that it could be done simply and low risk of damage by opening up the cluster and spinning the individual numbers But it sounds like that might not be a good idea.
Spin it at like 20000 rpm and measure the voltage. Then supply said voltage
IIRC, they are a pulsed signal, could build a simple circuit...
Yes, you can do it, but you have to completely disassemble the dash cluster to get at it. Even then, the pawl is very thin and if you break it, you scwewd. If you do decide to do this, use a set of precision screwdrivers to a) lift the pawl and 2) spin the dials. (shameless plug, my wife hates it when I do this!)
...Or hook up a frequency generator and dial it up into the Mhz and really watch that baby spin!
Pull driveshafts. Start engine. put in drive. Come back next day.
The gauge cluster will be removed for bulb replacements and dash refurbishments. I have two 80's worth of parts and I'm putting the best stuff I have on this cruiser. The cluster I want to use reads 8k less than the origjnal odometer. Not a big deal, but if I attempted to adjust the indication, I would be doing it manually. It sounds like it's not worth the hassle or the inherent risks involved.
If my math is right, and you reved the engine enough to simulate 50mph, it would take a full week to clock 8k miles.
Depends on how steady your hands are. Once you have the dial exposed, it'll take about a minute.
And over 700 gallons of gas. Could be less because your not under load but still.
May want to install the sub tank first?
It should be noted that altering an odometer, no matter how noble the cause, is a felony.
I would certainly never make a public statement indicating I had done such a thing.
To be above board you could take it to a speedometer shop and have them do it. Also if they break it they have to fix it.
As long as you state in your sales document that the odometer has changed or has exceeded mechanical limits and documented the change in mileage shown when you sell it, then there should not be an issue.
Odometers wear out, they are able to be replaced. As long as you are above board on it, it is OK. It's when you try to hide that fact is when it really matters. However, on a vehicle with 274,000 miles and it now shows 266,000 miles isn't really going to make as much difference to the person buying it as one with 16,000 miles going to 8,000 miles. COULD it still be a felony? Yes. You MAY need to get a certification letter from a qualified, licensed speedometer shop in your state. Please check your state laws.
My old pickup wore out (3) speedometers. The only purpose after the first one was so I could keep track of gas mileage and to know when to do maintenance. However, that vehicle odometer only went to 99,999 miles before it turned into a new truck again.
These odometers seem to start having issues around 210K up through 300K. My trip odometer broke, then jammed my main odometer until I did the repeated impact force therapy on the dash and the repeated poke-of-the-button fix to at least make it so the main odometer worked and don't touch the trip reset button again!
Send to a speedometer shop and call it good if you are worried about getting it dialed in. If not leave the mileage as is and write it down in your notes.
The only reason I considered swapping the gauge clusters is because the first digit of the trip meter currently installed does it rotate.
Can the trio meter alone be swapped? With gps and phone app's, does anyone use that trip meter anymore.
