Build A pig for Father's Day
In doing some research I found out that the 40 series side marker light lenses are the same as the 55. Unfortunately the lenses are NLA but you can still get them if you buy the 40 series assembly (~$30 each). In doing further research, it appears that all the parts are the same except for the gaskets. Would love to find a NOS LH assembly to get the new gasket and/or find a source for the gasket. So far I haven't come up with anything.
I can't remember exactly, but try Cruiser Corp. You can still get the one side gasket, but you can flip it and use it on the other side. There will be two drain holes facing up, so just "black right stuff" them. I did mine and nobody can tell. I'm talking about the large wedge gasket, if that makes sense.
I tried Cruiser Corp, City Racer, and Slocruisers. Cruiser Corp had the OEM FJ40 side marker lights but I didn't see a gasket or assembly for the FJ55 side marker lights on any of those sites.
Edit: Tried a google search and these came up on Cruiser Corp. Did the earlier FJ40 side marker lights have the same gasket? Must have if these fit.
Second Edit: Just noticed those are the early front marker lights for an FJ40. None of the part numbers (assembly, gasket or lens) is the same for the FJ55 rear side marker lights but they do look very similar. So are you saying these gaskets work for the 55 side marker lights? They are out of stock or I would order a set, or at least one, to try.
This is the one, not 55, but will work. But two and flip one over then caulk the two water drains, so you can't see them. They have close to the same angle to them.
Well I bought a set of these: Genuine 69-75 Toyota Land Cruiser FJ40 FJ45 Side Turn Signal Marker Lights Lamp* - https://www.ebay.com/itm/154522672760?_trkparms=amclksrc%3DITM%26aid%3D1110018%26algo%3DHOMESPLICE.COMPLISTINGS%26ao%3D1%26asc%3D240417%26meid%3Da0f77fbde99946eaa3eb51524ab7762b%26pid%3D101196%26rk%3D5%26rkt%3D12%26sd%3D133714639947%26itm%3D154522672760%26pmt%3D1%26noa%3D0%26pg%3D2047675%26algv%3DItemStripV101HighAdFeeWithCompV3RankerWithKnnRecallV1%26brand%3DToyota&_trksid=p2047675.c101196.m2219&amdata=cksum%3A154522672760a0f77fbde99946eaa3eb51524ab7762b%7Cenc%3AAQAHAAABEA%252FJiT7ssNXrEsx1zZncFUUkLU8ikMh%252FiWOsxkTqeqIbE5K4lpcDSKjAfQ%252F1if83xZmFUlaqOee9xj8xMB8CDxcxiBHxOwvyx30g1t67FelLs1ZqlUnQE8PMVmILU1qWw288AZ9Y2Q3lTw6fU9UeOwsQSWRnviV6U8itxq%252F6qds0A4%252B1FYtFdW7iCuAhkvJHr2bLFr9QltqJCGx7fe2o6KJSZqoeIsRz9FjrlvyzDkFOfro8B6rJ92wCpUybWu5fG%252BYZMH0jkTS7VnR0mRSebLsvjImroXNCGLEQIg%252FWCL3b%252BnvTn%252FQ%252FCN6ZS0jgQd2xU3bZWxMhTb%252BEo6oIKzRqb%252FXmSXoxuddFhikDy9A75JrC%7Campid%3APL_CLK%7Cclp%3A2047675&epid=2265251069
I will report back after receipt. They are front marker lights for something like '72-'74 FJ45 variants. Looks the part and there appears to be good availability. Of course at almost $100 for the pair delivered it may not be to everyone's liking for a pair of gaskets.
Here's the gaskets I used, $7.95 and I'm assuming still available from Toyota. You can see the silicone sealer on the flipped one. 🤷‍♂️
Turns out I only had a pair of NOS surround bezels for the side marker lights and not the actual light assemblies. After searching the internet far and wide (and checking with Yemen, etc.), I found the RH light assembly on a Japanese Yahoo auction with a buy it now price of around $15. Emailed Dave at Japan4x4 and he was kind enough to purchase it and send it to me.
Was out of town all last week but plan on visiting a few shops of various ilk next week to see if I can find someone to tackle this ginormous dent. The company whose driver hit the pig have been very good about communicating that they will cover the costs. To paraphrase Carl (Bill Murray) "...so I've got that going for me". :D
Plaza Body Works on Pepperell Parkway repaired a bad dent in a Miata trunk for me and it turned out well. That's all I have for a suggestion of a body shop in the area.
My son, @cruiserinsanity, is working at Eagle Imports in the afternoons. He was telling that someone with a red and white Pig had come by the shop before he had arrived at work. Sometime earlier this week but I don't remember the day.
Thanks Jim. That would be me. I just stopped to inquire about that Series Land Rover that was sitting out front. He said that one of their employees was an FJ55 fanatic but wasn't at work. I think it was Tuesday.
@WarDamnEagle I’m the fanatic, I’m only there after 12:00. If you see a tan FJ60 sitting closest to Byron’s please stop by again sometime.
Easy peasy Gavin. I look forward to meeting you.
Well the gaskets will work well even though they are not 100% identical. They are more or less identical in every detail except the front marker light gaskets are ever so slightly higher in the rear and ever so slightly thinner in the front. In plane view they look identical. Even the weep channels are the same.
Here are some photos with OEM rear FJ55 on the right and OEM front FJ40 on the left. Both are for the right side. Last photo shows the part numbers again.
ZL1, all Aluminum big block with stonecrusher 4 speed tranny. 50 were built, with 37 being returned to GM. Would be 12 sold. 😉
Winner, winner, chicken dinner. Spoke to my friend today. He said 69 were built and only two in yellow. This is one of them.
In related news, I made a video of this ZL1 running today. I'm not smart enough to post videos so if anyone would like to on my behalf (in this thread please) them please PM me a phone number and I will text you the video. That is one wicked sounding engine considering it was OEM in 1969.
OMG; previous owners.
Greg if your not gonna use that insulation I could probably use it on barn project….
Looks better now. I’ll save the insulation for you. 😂
