Yeah the lockdowns are making things rather hard indeed to progress with this sort of thing that usually require travel to machine shops etc.
if it makes you feel any better @mudgudgeon I’ve just popped the bottom part of the sump off today in preparation for lifting out my engine and discovered the tiniest bit of fresh green coolant in the bottom
so now it’s not just bottom end bearings and big end bearings it potentially the head gasket at a minimum and I’d be willing to bet if I sent the head off to be decked they’ll say I need a new head roughly $2k AUD
so I’m now on the hunt for a second hand 1FZ-FE and I’ll probably sell mine off cheap to suit rebuild.
you can see the green dots on the shelf of the oil drain pan along with some of the flakes of bearing I assume.
This white goo was also sitting in the bottom of the sump.
And I was having this kind of moisture? build up on the inside of the oil filler cap regularly when the car was being driven.
All points to head gasket I would think. Which is exactly what I didn’t want
