- Thread starter
- #41
Still waiting on return of my crank, and parts to ship.
Spent some time cleaning parts.
I'm replacing timing chain guides, and tensioner.
Guides are worn, and plastic guide surface is degraded and crazed on both guides with a few small chips missing
Also found the source of aluminum swarf found in the sump.
Power steering pump gear lock nut came loose, and backed off until it hit the timing cover. The pump gear also floated along the shaft and contracted the back of the timing. Timing cover has a neatly shaved mark from the gear, and a less neatly shaved groove from the nut.
Oil pump is pristine!
