What stage did you order Dozer? I thought the Mill Creek website said they were out of stock on the stage 1 and 4.
Edit...they just answered !!
I already have an Icon set up, so all I ordered were the HD slinky rear springs (they didn't have the fronts in stock). There is a lot of demand out there for this stuff right now, so I'm sure they're out of a bunch of stuff.What stage did you order Dozer? I thought the Mill Creek website said they were out of stock on the stage 1 and 4.
The owner, Albert, said the springs are on a boat heading our way. He expects the springs to arrive mid June.I already have an Icon set up, so all I ordered were the HD slinky rear springs (they didn't have the fronts in stock). There is a lot of demand out there for this stuff right now, so I'm sure they're out of a bunch of stuff.
The new vendor/dealer is Mill Creek OverlandI’ve tried searching online to find a US dealer. It appears the 4xusa website is down for maintenance. Are they the only USA dealer for slinky right now?
I believe you can trim some of the dead coils (the ones that are coil bound until you have a lot of droop) off the top to adjust the height up front. For what its worth I also needed to go to a DC front driveshaft to get things to be happy vibration wise. Suspension rides great!Question here on the 3" intermediate lift. But first since background. I just installed the rear 7501 coils. I have a 97 with 4x4 Labs bumpers and sliders, spare tire on driver side. Winch w/ synthetic rope in the front bumper. Some recovery gear in back but nothing that affects the lift height as I moved it from left to right in the back and got the same measurements. No roof rack, no drawers, no 3rd row seats, one battery, no aux lights.
The cruiser has always run a bit stiff when not loaded with 5-6 people plus all the gear that can be stuffed in the back and in a cargo box on the roof. Then it rides like a dream, loaded as much as possible. It takes speed tables as well as my minivan when fully loaded instead of like a leaf sprung Suzuki Samurai when it's just me and three small children. Ok, it is still way better than the Suzuki. Initially, with the HD springs the driveline vibrations were unbearable on the highway despite reassurances on this forum to the contrary, assuring that a dc driveshaft wasn't necessary. That still may be true with a 3" lift but this was a 4.5"-5" lift. I installed a DC driveshaft which took away most of the vibrations but they were still there if I took my foot off the gas at >65mph. With the intermediate lift, highway vibrations are gone (still have a front dc driveshaft). I already have 2"spacers for the front swaybars, delta radius arms, HD lower control arms, rear adjustable upper control arms, and a Delta panhard bracket in the rear all in an effort to make a simple 3" bolt on suspension ride nicely.
But let the record show that this suspension has been awesome, especially when I've had 5 people in it. Great on high speed desert stuff, great in crawling situations. I really enjoy the suspension, hence I'm just trying to lower it a bit so it's closer to 3" of lift and rides little softer unloaded. It's not a daily driver, but it does frequent nearby trails a few times per month.
Before ordering the springs last January, I had consulted Darren and was instructed to get an HD setup with 7511 coils. I think the 4x4 Labs armor is comparatively light and I just ended up not adding a ton more stuff that is typical. It's not as heavy as expected.
Here are the lift height measurements:
Rt front 23.75"
Rt rear 23.25" before w/ HD 24.5"
Lt front 24.25"
Lt rear 23.75" before w/ HD 25"
So, given that I now have a reverse rake when unloaded on a path reminiscent of 2nd and 3rd gen 4Runners, what can be done to help address this? I do not necessarily want to drop to 50mm front springs, I really like the ride and travel of the current front springs.
I think I've read Darren mention that coils can be trimmed but I can not find it anywhere and am now questioning my memory. Can a coil or two be trimmed from the front? Will the shocks be too long at that point? I've read about someone trimming the rear spring coils, but not the front coils.
Scott
Here is a snip from Darren:
Slinky
Free height is 24" front 22" rear.
Our slinky coils for front are 260 lb [SNOWY has these]
rim to fender is 800-825mm, and because the last 2 5/8 thick coils are completely dead, it allows us to trim heights to suit by removing a coil if we need to.
