The only 2.0s I have used that I would recommend are the ICON stage 1's, 670mm [26.5"] long, front and rear, valved nicely, suit a vehicle up to around 7000# .
Best bang for your buck 2.0 set up IMHO.
The other "OE" style 2.0 manufacturers I have tried all are acceptable for an elderly gentleman who wants "factory ride" on a stock truck, which also sucks.
2.5's are a whole new ballgame, and valved correctly work extremely well on an 80, especially a heavy 80.
For a 2-3" lift, I would save longer for these with CDC over any 2.0.
91-97 Land Cruiser [80 Series] Performance Shocks System Stage 3
Add CDC from the ICONS, which uses a second piston in the resi, and valve stack, rather than a pintle style adjuster which ups line pressures massively, and you can tune to suit more or less weight, and the way the valving works, the ride is more like 15-20 psi in the tyres on the sharp road bumps, but really soaks up the big stuff. The hose coming manifolded off the body also helps, with the full valving of the shock in the last part of the up travel making for a built in bump zone inside the shock.
It will sit flatter, nose dive alot less, be smooth on the bumpy stuff, and give the bump stops a good rest on the big stuff if you drive it like its stolen.
We have used, had custom made, imported, and built pretty much every major brand of shock from our shop, OE, Pre runner, and Race series, and after beginning to use the Icons, we went to Icon only, because of the way they work, the product, and the ability to make what we want for our market as well.
Icon make alot of custom stuff for us, for our market, mainly Cruisers, our slinky long travels with tapered wire, sway bar links, spacers etc as a bolt in, uses a 12" stroke front and rear, to suit trucks up to 9500# in a 28" front and 29" rear ext length with install kit.
One of those moments where you meet with companies, try products, and end up being able to sell what you do because its the best you can get, rather than all you can get.
I have just installed custom coil overs and bypasses in mine, took a friend for a hell ride last night, with jumps, spoon drains at 45 degree angle turning off the road, at 50 mph, rough train line service road potholed wheel tracks etc, after getting it dialled in.
I think he liked it.
He has stage 1 icons in his 80.
They flex ok too.
