- Joined
- May 20, 2008
- Threads
- 15
- Messages
- 917
- Location
- Central Victoria, desert region.
- Website
- 4xoaus.com.au
Interesting project, not unlike some previous ones you have done either.
Lighter than OE coils dont swap out of anything else, and unless the vehicle is stock empty no rear seats etc, and no spare wheel, I think you will find they wont be enough.
Of course our biggest market is "overlanding" so we can fit out Cruisers with 8000-9500lb total weight on 35s, fully fitted up, too.
10-11" stroke shocks will work with original brake lines and sway bar brackets, just, diff breather will need to be a bit longer, and keep the coils captive, just. Add a good monotube high gas pressure shock would help with stability, as the 80s tend to rock and roll with the standard coils if the shocks arent good, and the std sway bar. They also tend to bobble front to back when coil rates are similar each end.
80s also tend to work the front bumstops hard, with the low spring rate they have, especially with dual batteries winch and bar all mounted up front, and the big 6 hanging over the front axle a little. I like to be able to hit stuff sometimes without having to react to the bump stop reaction. Due to the front being a little restrictive to lots of articulation, heavier front softer rear works well in an 80 in my experience.
I had an 80 here that was going to be a similar built to yours, wit 40" tyres, and I was going to use our slinky long travel set up in the truck, with 12" stroke front, and 14" rear but cut the coil mounts and shock mounts off and move them up so the standard bump stop position was used as the start point. Cutting the rear tubs and raising the floor a little would of fitted the tyres, kept the drawers and storage in place, and instead of 70mm lift we would of been 0 lift, with 1/3 up travel and 2/3 down.
Since then, we went back to the bolt in a frame rear uppers, and we are working on 17" stroke rear shocks with longer lower links for better drive, and less roll steer, on 70mm lift, with higher mounts and just 2 hols in the floor that are sealed to outside. We are developing some new Super Slinky coils to work with these 17" stroke shocks and stay captive with the longer arms and a frame top mount which eliminates the panhard rod as well.
In the front we are working on keeping the 12" stroke set up and slinky coils, with most likely a 5 link set up, or modified X link to keep on road manners.
2 big things we do for on road stability is to add negative camber to the front axle, for bigger tyres, and at least 3 degree caster. I like to run 3/4 degree at least neg camber to make the front pointy, and with good high pressure monotube shocks, and a heavier rear sway bar to help with roll steer, turn blend lanes at traffic lights jumping the kerbs while over GVM, or 2 wheeling it over roundabouts while throwing the truck around arent scary propositions for anyone but the passenger
For bigger tyres, we also move the front axle forward an inch, and can get another 3/8 inch from the offset bushes we use.
We have also done a coil over and bypass set up for the 80 front, using 12" stroke 70mm lift, to run differing coil rates, for more control with our slinky long travel 12" stroke bypass rears.
Currently building my 21st 80 series, which I should start a build thread on, a 97 40th Ann turbo intercooled petrol version, with bypasses, 35s, injected lpg, and all the usual stuff.
