Build 73 FJ40 Refresh
Member Build Threads
I found these silicone caps on amazon, it works well to keep dirt and grime out of the quick connect
for the on board air.
Everything you have shown in these posts and pictures has been done in such a pristine and precision way… I really am looking forward to the completion video!
Doesn't your winch line have a loop on the end? If so, how are you going to attach the hook?
I finished the cowl vent knob bracket and the washer nozzles. I need to find someone to 3d print those plastic trim rings for the washer nozzles because I don't think they're going to hold up very long. I had the under hood pieces zinc plated and added a new SS M6 nut. The cowl vent rod bracket I think is normally welded to the dash. Mine was missing. I had the bracket zinc plated.
The grommet on that cowl vent push/pull rod must be used in a few places because I found I had three of them.
