60/62 later model parts upgrade or interchange
Yep, the front wiper arms (get both from left side) are 85221-35080, and the cover is 85192-12800. I haven't ordered the rear 80-Series wiper yet.
Here's a photo from another thread of the 80-Series rear wiper arm with part number:
Through whom did you order the parts? O'REILLY didnt carry them.
Is that a dealership?
City racer had the set. I just ordered from them because I didn’t have the part numbers at the time and it was easy. I don’t think it cost more but I don’t get a 25% discount.
Intermittent wiper relay and hazard signal relay. I’ve got ‘83 60 wiring and is there a a solid state
upgrade that gets rid of the gears and wheels relay for the wipers?
Regarding the hazard relay, if you snip out one resistor you can run LEDs bulbs in the flashers without the fast blink problem.
Don’t really want LEDs. But seem to create too much resistance through the hazard flasher. Maybe I’ll try an ‘88
flasher and see how it works out. Is the part number for different from earlier flashers?
Has anyone found later model wiper relays that work?
I used an earlier one because it was documented to work. Not sure on the later ones but I didn’t try.
Thought I would put together some options for fog light/accessory switches using Toyota parts. I like the Toyota switches because they match stylistically and getting used ones are pretty cheap via ebay or junkyards. Most of these switches will need to have a little fog lamp decal added which should only cost a couple extra dollars. Lots of other Toyotas from the 80s and early 90s have fog lamp switches or other defrost switches that can easily be utilized for running fog lamps or whatever accessories you want honestly. Lets add to this list! What else have other people found? I'll update this list as new stuff is found.
FJ62 style opening:
1984-1989 Toyota truck "deck lamp" switches can be easily converted for fog lamp use. (run about $20 on ebay).
1988-1990 FJ62 rear defrost switch
1988-1990 FJ62, other JDM Toyotas of that era as well, fog lamp switch (rare)
1991-1995 MR2 fog lamp switch (looks like it MAY FIT, someone needs to test this).
8416090K01 - New Toyota fog lamp switch (but graphics are sideways when mounted in a 6x series).
84165-20070 (looks like it MAY FIT, someone needs to test this).
84160-52030 Scion switch (looks like it MAY FIT, someone needs to test this).
FJ60 style opening:
1980-1987 FJ60 rear defrost switches
More good OEM fog switch info (80 series) that could be useful for some of these switches: Early OEM fog light switch Part No.? - https://forum.ih8mud.com/threads/early-oem-fog-light-switch-part-no.219791/
Decals:
via @63FST Interior Decals (4) New Kits To Consider - https://forum.ih8mud.com/threads/interior-decals-4-new-kits-to-consider.1255486/
via @NLXTACY SWITCH RELABLES- printable single sheet - https://forum.ih8mud.com/threads/switch-relables-printable-single-sheet.274776/
Thanks for mentioning my kit -- this type of upgrade is exactly what I had in-mind when making the decals.
It's been posted before but I have a picture of my exact decal on an OEM switch and it looks very good.
-Mo
