Wanted 4.10 fine spline diff needed
Status
Not open for further replies.
4 speed tranny and transfer case
Have you checked the oil level and condition in either gear box?
Found any metal on the magnetic drain plugs?
Checked oil, yes since I have owned it, every few months. No leaks, level never down. I am meticulous on maint. issues. I have never found bits of metal on the plug or in the diff fluid.
Thanks
I know what you are saying with the new unit. I want to keep these as spares until I need them
Someday I may yank all the Toy stuff and do a dana 44, 350 etc swap
Re:wtd: 4 speed gear
What is the teeth and spline count your looking for? Could be 31 teeth 16 spline or, 29 teeth 16 spline or 29 teeth 10 spline. PM me as I might have what you need or know where to get it!
FJ-80 Panhard Bar
Yeah, it's not too bad of a price considering every other panhard bar i find for sale is attached to a $1500.00 axle, thanks for the info though,Brad.
84 p/u drive shaft
I'm looking for a driveshaft from a 1984 Toyota pickup. I need 2, but just finding 1 would be a good start. Anbody that can help just send a PM.
Thanks!
78 window latches
I'm looking for rear wing-window latches for my '78 FJ40. I had some help putting my hardtop back on, and, forgot to warn my helpers to watch out for the window latches. It's been so long since I had the top off that I forgot how the broken one got that way.
Anybody that can help, send me a PM.
Thanks!
distrubutor bolt/nut
Hooked up the timing light, put the 10mm 1/4 ratchet down on the dist bolt and look what dropped on the floor...I put a bolt through there and all is fine but I'd like to get the original piece and put it back. I'd also not like to pay SOR $20 just to put it in an envelope if you know what i mean. If anyone has one drop me a PM
Re:70-74 FJ40 carb wanted
Carb. from a '71 F engine. Was running 2 months ago. $100 in Vancouver, B.C. but can send from Blaine, WA if desired. Also have carb spacer if required.
Got an Asian 2BBL. Came from CO. But I am in Columbus OH. The PO said it was from a 75. Does not appear to need rebuild. Clean. Have photos if you need them
100 bucks + the ride.
80: need Diff ECU, rear diff actuator motor
Actually fixed it.
Turns out the manual troubleshooting guide is good but fails to mention that u need to have all the wires connected to the rear otherwise the test results are not correct!
Interested in ECU as a spare (and other bits) if anyone comes across a junked 80.
Lal
HELP!!! HARD DOORS NEEDED
I need a set of hard doors in "used but still good" shape. I dont mind a little rust, or a lot for that matter. All I really need is a decent set of doors w/ glass to keep the snow and cold out. I know shipping will be an issue, I am in Omaha, NE and will meet you within 6 or 7 hours of my house. Please it's getting cold here and my wife wants her garage back.
Thanks
OEM Steel Rims
Looking for the OEM steel wheels - set of 4 or 5 preferrably. Have the white wagon wheels from the 80 FJ40 I bought which I will trade/sell as needed. Will pay for shipping or drive reasonable distance in NEast (located in NJ). Need something cheaper than SOR offers.
Regards,
Andrew
Are you looking for one piece or two piece? I've got two piece doors but I'm alittle farther than 6-7 hours from you, central montana. If you can't find anything closer get ahold of me. It's been cold and snowy for the last week, probably time to put the top back on. Paul
Status
