Spent the weekend finishing up small projects on the 40, re-covered my stock seats...
Hey Tucker, you've got to post pics of those new orange seats
Do I need to come over there this weekend and install the new tub for ya?
Ding, ding - having a new y-pipe made with O2 sensor bungsUmm, a few hints in the pic suggest a muffler shop.
Spent the weekend finishing up small projects on the 40, re-covered my stock seats (thanks Shane), cleaned up and painted all the brackets, and installed the interior and carpet. Then I installed the cluster and heater and started running the coolant hoses (need to buy some), then ran new cowl drain hoses. Also ran the throttle cable through the firewall and installed my Weber pedal so she's drivable.
I went ahead and ran hoses from the tank vents to the fuel separator before I installed the cover, it's just plugged at the output for now but will need to hook up the charcoal canister (this was all deleted previously). Found a small leak at injectors 3 & 4, will have to pull the plenum and re-seat the o-rings
Hope to have it at the muffler shop by Wed to have the y-pipe made
Tucker
Tell me more about the Weber pedal!
I am running a FJ-62 pedal in my 55 and it is uncomforatable!!!
Plan on it, your old seats cleaned up nice eh? Can't wait to enjoy ... err give you what we agreed on for payment around the camp fire next weekThose seats look great! I would of never thought of using that color!
Driving it to cruisers and coffee in the AM?
I seem to remember having a back pressure issue on my FJ40 install as well, and I think I solved it with a small whole drilled into my gas cap, or maybe I used a late modle gas cap..? I can't remember.
-Mark
My '76 has a sealed cap as it originally came with the separator/charcoal canister installed to vent the tank vapors. The tank was plugged and system removed when the PO desmogged the 2F years ago, never gave me issues with the low pressure mechanical pump return. I've got a separator but am looking for a 40 charcoal canister, the one from the 62 is just too damn big to put it where I wantInteresting. I didn't have this problem, but I am running a charcoal canister. I did have a problem with the way the canister was plumbed at the tank (tank manufacture porting), but resolved it by raising the source line so it didn't suck fuel, and pulled vapor instead of gas (job of the separator?)
Glad to see another successful 3FE install. Sure wish I saw 16mpg. Best I get is 14mpg.
So tuck, you mentioned in another thread that you're running an 80 series non-airbag steering wheel. Could you throw up a pic of that setup? Never heard of that or seen that before.
