I posted a sneak peek on Monday of a DC Power Inc 270 amp alternator I ended up purchasing for the Cruiser. I got around to installing it, along with the wiring kit I had user @Fourrunner make yesterday. Wanted to give everyone the low down on the install.
First of all, my reasoning for grabbing this alternator was obviously the anemic 80 amp stock alternator. And, since I've had my winch for about 4 years now, I've run into scenarios where I'm doing 6-8k pulls, and the battery and alternator are just not able to keep up. Literally only getting 30 seconds to a minute of pulling before the system conks out.
It could be that my Costco battery has been depleted too many times over the years to give me a strong reserve of power, but I know that the 80 amp alternator is only giving me about a 1/3rd of the power needed for an 8k pull, according to my winch's spec sheet. To do a dual battery system seemed like several hundred bucks to begin with, and would only give me twice as much pulling time along with twice as much charging time needed. So I thought a more powerful alternator would be more cost and performance effective out of the gate. I still may end up doing a dual battery setup down the road.
Cost of this alternator was $630 + $20 for shipping. Pretty hefty price tag, I know.
Onward to the install....
I've only seen 1 other post on here indicating that the install only needed a slight modification to the bracket. Well, this install took for far longer than thought, and I ran into quite a few things that I thought I'd pass along.
First, to get this bad boy into place, the return coolant hose, distributor and top alternator bracket needed to be removed.
The top bracket needed to be ground slightly for a nice easy fit.
Once you I got the alternator into place, I was able to get the top bracket reinstalled. And then I noticed that the bottom screw holes weren't tapped correctly to accept the stock oem bolt of 8 x 1.25. They seemed to be tapped for 7 x 1.25. I ended up tapping one of the holes for the proper 8 x 1.25.
Then there were fitment issues with the lower swing bracket. The alternator was simply too big for both mounting points(nut and bolt). I ended up just using the left mounting nut side along with the tension and lock bolts. I felt that the bracket itself was such a tight fit it wouldn't move anywhere.
The only other issue after that was that the alternator was so big, that it didn't swing close enough to the block to allow me enough tension on the alternator belts to slip on. So I had to remove the lower bracket and to bracket to cock the alternator diagonal to allow for the belts to slip on. Then reinstall top and bottom brackets again. Fun times. I can imagine any kind of trail repair to be lots of fun.
I did finally get it installed. Whole process took me about 8 hours, way longer than I anticipated. Aren't most repairs on the Cruiser though.
Anyways, I thought I'd give folks a somewhat thorough alternative option to getting more electrical power. Next time I'm up in the mountains, I plan on taking some video of winching performance. I'll post another thread when I get around to that.
