1HZ install into a 1978 FJ40
keep up the good photos (and the good work, of course)
Congratulations Wayne you are "almost" there I been Following the progress since day 1 , and just want to know you are doing a great work and very professional , to bad I dont have the money to do my own at the moment but when I start I know where to look.
Cheers from South America.
rear drop box
now you see it, now you don't.
<it is HUGE>
front drop box installed
now you see it, soon you won't.
it hangs down perfect for the side bars, almost invisible.
thanks for the compliments guys, i appreciate it.
i have 11 days left to complete it and will need every one of them.
the black side steps really compliment the green body tub...
the skid plat for the tranny cross member bolts installed
driver mirror and windshield hinge installed
passenger windshield hinge and mirror and custom mount. we needed to do a custom mount due to the snorkel. you can not use the hinge mirror arms since they stick out the front. after a bit of debating it was decided that this is the best solution. now that it is installed it just makes too much sense.
Hello Wayne,
The rig is coming along great. Keep going, keep up the good work.
Can't wait to see the final product!
JuanJ
the primary battery stand mounted and extremely solid, you can rock the truck pulling and pushing.
the locker locked and unlocked.
the switching is dead simple.
i looked all over mud for a simple system with no relays and couldn't find what i wanted anywhere. i am sure it is there but i couldn't find it.
so here is what i did (schematic to follow):
on all the 80 and 70 series wiring harness the
red wire is light indicator for engaged.
white wire is ground
solid blue is engage
blue with strip is disengage
so you need:
momentary up and down rocker switch with 6 plugs
<Cole Hersee Co model number 58027-11 617-268-2100 Ma phone number>
positive feed to one center
ground feed to other center
solid blue to upper right with jumper to lower left
blue with stripe to lower right with jumper to upper left
push up to engage for 2 sec
push down to disengage for 2 sec
for indicator light:
white to ground feed
red to one side of indicator light
positve feed to other side of indicator light
light comes on when locker is engaged.
super simple.
these are all the pics but there was a LOT of wiring run today in preparation for the dash fitment.
wires for:
air box indicator light
secondary fuel sperator indicator light
extenstion to e/brake indicator
speaker wires front and rear
power feed to center tuffy box
power feed to stereo
check back tomorrow for more.
mounting the e/brake with all new hardware
making the e/lock switch mount plate
locating the idiot light plate
wiring, and more wiring
brake master and clutch master installed
note: this is the mock up dash, the new one is still a virgin:
the elocker switch located
with dash
with 4wd switch installed
in the finished face the lettering will be properly located and the "engaged" lights will be where the dot is.
the new power steering reservoir
the custom plate designed by Rusty
where it goes.
problem is the mounting of the e/brake cable did not match the housing on the disc brake 70 series rear axle.
one issue i had with the manafree bumper was the lack of grease nipples for the swing out accessories.
it has nice brass bushings inserted so 2 grease nipples drilled and taped per corner and life is good again.
i like the result.
Enter Maximum Safe Engine 1900 RPM
Enter Tire Size Diameter 33.5
Enter Differential Gear Ratio 4.11:1
Enter Transmission Gear Ratio .85:1
Potential Calculated Vehicle Speed 54.22485295821492 MPH
87.26644175918544 KM/H
Enter Maximum Safe Engine 2400 RPM
Potential Calculated Vehicle Speed 68.49455110511357 MPH
110.23129485370791 KM/H
Enter Maximum Safe Engine RPM 4700
Potential Calculated Vehicle Speed 134.1351625808474 MPH
215.8696190885113 KM/H
so wicked fuel economy at 55 mph or an insane top speed for a 40 series...
