1990 HDJ81 - Introducing "La Mia Bella Bestia"
Nice truck, looks oddly similar to mine!
i just rolled over 100,000 on mine and did the t-belt. To change the belt and tensioner is about a 45min job if you don't have issues with the spring for the tensioner.
Chatting with our Aus. brothers they say the water pump is good to 250k. My question is, do I need to drain coolant to change out the water pump.
You can either drain it, or watch it drain out when you pull the water pump off, lol.
Overboost, should come on only when you exceed 12psi.
I don't see it as overboost.
My reason is; it glows, not a steady intense glow but comes and goes in intensity. It never "Turns on" this is during the full spectrum of boost from 0 to 13. I am wondering if it indicates boost leak, although I haven't found any indication of that either. It started doing this when the timing belt indicator came on, I thought it could be light bleeding from that indicator, but that's a good distance away.
As your factory sub is already removed, you could maybe mount something there? I'd keep the factory panel personally, I'd hate to lose the storage pocket for the winch control, etc.
