Build 1978 US Market FJ40 Factory Restoration
Side marker install. Straight forward. I had to clean the threads of the m4 screws. If only all cruiser projects were this satisfying.
You'll never believe this. I need to order more parts.
In the meantime, I do have the wipers to do, so I'll knock that out quick. I cleaned up the linkage with brake cleaner and re-lubed with super lube.
Along with the linkage, you need the main "keep" thin nut and retaining washer. Otherwise, here's your parts kit:
From the outside, it is Packing, retaining washer, nut, cap, wiper arm, nut and then cap:
Will make adjustments when I can power them on :-). Another fun item checked off the list.
Question: as I work to seal up the firewall, I'm noticing what most vendors carry for the heater cable and choke cable firewall grommets for either to 75 or to 77. There doesn't appear to be any part #'s for the 78. Sources? Will the earlier grommets work?
Choke/coolant temp grommet is larger than heater grommet. Original is 90480-30003. Used to pass CTS and Choke. NLA for the grommet, but haven't hunted for any other options yet.
A few more projects this afternoon.
Antenna:
New Dash pad. My old one wasn’t awful, but had a few cracks and again stuck out.
Exacto blade the map light hole:
I ordered new hardware and spacers, but the new dash had spacers already inserted, so I just needed to salvage the retaining bracket and install.
A couple of detail questions. I've never known the proper way to vent the distributor. Maybe I'll check the emissions manual. Looks like this is venting into the cabin? Whats on the other side?
Also - looks like there are two hard lines for the charcoal canister - one up top along the hood line and this one - any ideas where this goes? Again, this might be in the emissions manual - I'll check there next.
Thanks
If I could figure out how to create a poll within a thread....I would. However:
What would you do:
A) Spend 50+ hours of body work perfecting the original hood. It came with the cruiser, after all and you've come this far.
B) Roll the dice on a Topnault replacement hood. All you'd have to do is verify fit and form, prime and paint.
Questions to consider - any loss in value either way? Pros and Cons are somewhat obvious, but anything I'd be missing?
What would you do:
Topnault is doing very very good things but I don't believe its exactly the same as oem. Perhaps source a used hood in good shape if your old really needs 50+ hours of body work? What you've done is unbelievably good....I think you probably know the answer already. Keep up the good work. We're watching in rapt attention at the detail.
A hood is an easy paint-and-install-later project, since it's not interconnected with other parts. I would work with the one you have, paint and install, and if you find a minty-perfect hood later on, you can paint and install that (save some paint for this). You may have a long beard before a rust-free minty hood shows up on Long Island, however.
Awesome @OhioFJ and you even used a red line. Where did you find that burnt orange colored vacuum line?
That’s chestcutter’s truck, I just remembered that he wrote about sourcing that part. Maybe toyotamatt would have that orange line?
