- Joined
- Dec 12, 2006
- Threads
- 79
- Messages
- 3,652
- Thread starter
- #421
Both sides fully welded it in stages. Check fit between stages. Beads ground flush.
Guess is less than 20lbs. Mark says he’ll weight next time it’s off the truck.How heavy is that beauty and beast of a skid plate?
There are three sets of 70-series axles at mark’s shop. The locked set off the hzj75 troopy goes on that 1976 fj40 with a 6.0LS and a Tremec 5-speedWow - that skid plate is crazy complex, my 40 has a similar design made by Don (FC Fab) and he just dropped each side with a notch for the DS. I went to a 70 series rear axle so I could loose the drum on the split case however.
I would have certainly guessed more. Incredible work regardless.Guess is less than 20lbs. Mark says he’ll weight next time it’s off the truck.
It’s 43 lbs.I would have certainly guessed more. Incredible work regardless.
Over. 5 k budget
Wow, those are some beautiful welds!!!Inserts tig welded in at 125amps 1/16" rod. 1/4" mounting plates, 4x 7/16" bolts. Inserts are .75" deep.
That is some strong work!!!
That is brilliant work!Preloaded the crossmember up 1/8" to account for the compression in the trans mount.
Added gussetts. Pulled it once to finish on the bench. Reinstalled, then took the temporary brace off the tcase.
Going to add a couple drain holes.
Great view of the header collector:Preloaded the crossmember up 1/8" to account for the compression in the trans mount.
I like The Goblin!Mark. He does a ton of 60s/70s era C10, Camaro, etc work.
in addition to BATPIG, he has the 1976 FJ40 (formerly known as the Goblin), my two stretched FJ40 projects, and the wife's 1965 Mustang.
The 1976 FJ40 is getting a rebuild: LS364/450(*), TR-4050 5-speed, split case with 3:1 lo-range, the locked / 4 wheel disc axles I have from a hjz75, fabricated fenders, 35s on 15x10 widened Toyota wheels, full cage. It's next after BATPIG, more of a trail truck, but staying SUA. Bunch of work upthread on the 4-plus rear bumper.
(*) people have asked if I plan to do wheelies. The answer is, 'No'.
Man that is a perfect Pig piece!!!3/16" gussets added. Tig welded at around 200A, manual pulsed, 3/32" filler rod.
Let it cool, then tune up of edges and it goes back in.
Those look like perfect crossmembers.On its own weight. Still 3deg down
These guys are absolute craftsmen...Skid plate taking shape, continuous piece of 1/8" plate. Hugs the trans crossmember and as tucked as possible all the way back.
