Build 1974 Pua'a
Short people got no reason, short people got no………….
I could not use the word i wanted ? so i went ( WOKE ) LV is made in Japan:rolleyes::rolleyes::rolleyes::rolleyes::rolleyes::rolleyes::rolleyes::rolleyes::rolleyes::rolleyes:
That LV was mine years ago , I wounder if he knows it has 373 gears in it ????
Yup. The stroked 5.2L 1fz-fe is gonna love it.
Does @scrapdaddy still have his spare?
Yes he does and shipping cost is all I'd ask, just taking up space here.
EDIT... Sorry, I must of over spoke. I can't find the crossmember, it must of went to the scrapyard. If it turns up I'll let you know.
@samc2447 sent me the following this morning (edited for clarity):
I went to the body shop yesterday to check on the 74. I took over another 74 that was untouched so they could take measurements. While I was there we checked some areas and the rockers are over 1/2inch out and not parallel to the body, which is why the door gaps are so inconsistent. The B pillars are out too. They have cut things back and were using some hydraulic rams to get things closer, but more needs to be cut back and rewelded in the proper positions.
So my question for you is how deep do you want to go with this? It’s all fixable but won’t be a simple fix.
That guy in Killeen did a number on the truck.
Fortunately, I might have a solution. I just have to move it from Maryland to Houston.
That Sucks!! Probably no cross bracing when they cut into it??? 😡🤬
It had cross bracing, he just sucked
They messed up your '74 body?
Glad you got it out of there before they did worse...
Kudos to @samc2447 - sounds like it was a timely visit!
