About a year ago I got the idea to find a way to restore the markings on my gauge cluster. After doing some tinkering with the a cluster, I drew up some artwork originally intending to silkscreen the gauge faces.
Well that would be a lot of work, and would be limited to the screens I would make. So I did a bit more research and settled on precision cut adhesive backed vinyl. I then looked into the types of vinyl and found a marine grade premium vinyl in matte white to make the markings out of.
That allowed me to make the markings to take my gauge cluster from this:
to this:
If you look carefully (or not so carefully) at the speedometer markings you will notice the after picture is quite different from the before. That is intentional.
While I was tinkering with the cluster and creating the artwork, I figured out how the speedometer worked. This allowed me to correct the speedometer for the 33" tires I have on my FJ40. The way I see it, if I am going to spend this much time cleaning up and restoring my cluster, might as well make the speedometer accurate.
I also replaced the foam that acts as a light seal for the turn signals and high-beams and repainted the needles the correct orange color while I was at it.
The cluster goes back in the 40 tomorrow, but though I would share the development with Mud.
I will be making these available in stock, 31", and 33" tire configurations. I can also do custom tire sizes based on my calculations.
*Disclaimer: I know that the odometer readings are different. My FJ40 was sold to me mileage unknown and the odometer reading is not used for insurance purposes. It more for my information.
to this:
