I had hoped to hear the ol' 2F roar back to life this weekend, but no joy!
It appears the problem is with the ignition. Fuel is good - I'm pulling fuel from the tank to the rebuilt carb, via the new pump no problem. Starter is good and strong, battery well charged and putting out 12+ v. But, no spark.
I searched the threads here, but did not find anything that gave me a complete diagnostic or any "where to go from here" suggestions, so I decided to ask.
This is a '78 with the fully electronic ignition. Right now, I'm thinking it might have been nice to have the old points style ignition, because those parts are easy to come by here in Malawi. The electronic parts may be much tougher to source, and I am running out of time to get the mule operational. I'm now due out of here the first week in December
Here's what I have so far on the electrics: No spark from the coil (actually I get an occasional very weak, yellow spark, but I have to practically touch the HT wire to the valve cover or head to get even that.
Starting from that unhappy point, I checked, per the FSM, voltages between the LT terminals on the coil and the spark ignitor body/ground. The FSM states "approximately 12v" to each terminal. I am showing 6.3 +/- to the the positive terminal, and 0.9-0.8v (!) at the negative terminal. Also checked ohms as indicated in the FSM, and the coil (Toyota OEM - ND ) appears to be good in that regard. Since coils can be had here easily, I decided to try swapping in a new (presumed good) coil. The results are the same - 6.3v at the + terminal; 0.9/0.8v at the - terminal, no spark. This made me suspicious of the ignitor, so I decide to check the upstream voltage. I am getting 12v+ from both terminals in the connector from the wire harness that powers the spark ignitor. FWIW, I did not try the third test shown in the FSM - small battery to the ignitor plug, with the caveat to do this very quickly or risk damage to the ignitor. I'm working solo on most of this, although
helps anytime I ask, and Chris was able to come by yesterday when I was doing the initial troubleshooting.
SO.... what am I missing? The rotor and cap are good (new shortly before tearing down the Mule), HT wires all check out fine, and I suspect I would have spark to the plugs, if I had spark from the coil. Nothing was changed on the distributor during the teardown/buildup except the base clamp. I verified multiple times that the distro went back in correctly, and there is nothing I can think of that the distro would be adding to the problem, since there is no spark getting to the cap.
Any/all comments, suggestions, help welcomed.
TIA.
helps anytime I ask, and Chris was able to come by yesterday when I was doing the initial troubleshooting. SO.... what am I missing? The rotor and cap are good (new shortly before tearing down the Mule), HT wires all check out fine, and I suspect I would have spark to the plugs, if I had spark from the coil. Nothing was changed on the distributor during the teardown/buildup except the base clamp. I verified multiple times that the distro went back in correctly, and there is nothing I can think of that the distro would be adding to the problem, since there is no spark getting to the cap.
TIA.
