- Thread starter
- #21
Still no spark
I went back and rechecked every connection in the harness, all fuses, and everything else I could think of.
Next, I cleaned the bracket for the coil/igniter combo and made sure everything was clean. Swapped in a known good battery, delivering 13.05 volts, clamped the end of a heavy duty stranded copper wire into the negative terminal clamp to insure solid connection, and clamped this wire to the igniter bracket which is also the ground for the igniter.
cranked the engine while I held the HT lead from the coil to the valve cover. Nothing!
Not even the previously noted miniscule yellow spark. Pulled the HT lead and checked it - showing 14 kOhms, so it is good. Re-tested the coil for spark - good. Rechecked the power to the igniter at the connector - 12.4 volts. Rechecked the ground jumper - it was solid. Since I couldn't think of anything else to check at that point, I tried a different battery, delivering 14.05 volts, but the results were the same.
The only differences from previous attempts to get a spark were the total lack of spark and the fact that the coil and igniter both got warm this time - not hot, just warm, which I think must be normal for the electronic components.
I will check with Toyota tomorrow to see if they have the igniter or a substitute. I'll also check a few of the parts shops in Old Town - many of them sell used parts taken from wrecked cars, as well as new, mostly knock-off parts. I might get lucky there. Most wrecks here are rebuilt. Rebuilt rollovers make up a large part of the panel beater business, and vehicles that go to the car breakers are usually quickly stripped of anything that might be reusable.
Wish me luck
Not even the previously noted miniscule yellow spark. Pulled the HT lead and checked it - showing 14 kOhms, so it is good. Re-tested the coil for spark - good. Rechecked the power to the igniter at the connector - 12.4 volts. Rechecked the ground jumper - it was solid. Since I couldn't think of anything else to check at that point, I tried a different battery, delivering 14.05 volts, but the results were the same.The only differences from previous attempts to get a spark were the total lack of spark and the fact that the coil and igniter both got warm this time - not hot, just warm, which I think must be normal for the electronic components.
Wish me luck
