I'm swapping a hydraulic A440 into my 1994 FZJ80 as part of my swap to a 4bd1 diesel. In doing so there are a couple differences in the wiring I am trying to sort out. One is the fact that my A442F has two speed sensors. I am keeping the original tcase so the larger sensor mounted on the tailshaft housing of the tcase will be kept. However, there is a second one thats mounted on the driver's side towards the rear of the trans. What does it do?
I'm also trying to figure out how to wire in the lockup solenoid for the A440. The A442 has about five or six wires going to the solenoid where as the A440 only has two. It appears this is because the 442 locks up in the earlier gears instead of just overdrive in the A440. Any tips on wiring that bit up?
The last part is the neutral safety switch and gear selector. Anyone have a wiring diagram for a 91 FJ80 trans handy that they could send me? I need to figure out how to make the four position gear selector work in the three position spot.
