transfer case saver
Discussion in '40- & 55-Series Tech' started by megolfer, Apr 15, 2003.
  1. megolfer
    megolfer
    1,964
    92
    Jan 29, 2003
    How hard would it be to make a transfer case saver.  Also does anyone have any plans for one.  Any ideas would be great
    Thanks
  2. Niner
    Niner
    821
    Jun 4, 2002
    Readfield, WI
    Re: transfer case safer
    Please explain do you mean safer or a saver?
  3. megolfer
    megolfer
    1,964
    92
    Jan 29, 2003
    I meant Saver. Sorry Typo
  4. kc_chevota
    kc_chevota SILVER Star
    1,180
    74
    Feb 19, 2003
    Kansas city MO
    i have the crossmember that bolts to the back of the transfer case so i just welded a piece of angle iron to the crossmember along the top of the upper access cover then used longer bolts. I dont think it will ever move.
  5. woody
    woody Internet Fireman Staff Member
    10,333
    Media:
    303
    1,089
    Jan 15, 2002
    Toquerville UT
  6. woodsfj40
    woodsfj40
    1,000
    8
    Mar 16, 2003
    Olympia, WA
    I picked one up on ebay some time ago. Got a great deal on it, but haven't installed it yet. I am waiting until I am there doing something else, which will be the first week in May when I covert to a direct shift from my vacuum shift.
  7. cruzer
    cruzer
    586
    1
    Oct 18, 2002
    I just put one on this last friday night and it was great. Don was the man. I emailed him to confirm he had them instock, Paypaled him the money and i had it with in two days. Also he is running a sale right now..they are like 30 bucks plus 6 dollars S+H...i was going to fab one up but Why? for this price you get everything, painted, welded, cut, and the bolts.
    Scott-
    Got your MO yesterday...sending out the shifter parts today! Good luck!
    Stew
  8. Gus
    Gus SILVER Star
    1,127
    Media:
    8
    63
    Apr 13, 2003
    Ridgway, CO
    Looks like it'd be pretty easy to fabricate, it's just two pieces of steel plate welded together with a few holes drilled in it, but as Cruzer said if they're going for only $30ish + $6 S&H, just buy one. :G
  9. TUFFTORQ
    TUFFTORQ
    504
    Sep 18, 2004
    Is this type still available? If so, is there an updated link to contact the fabricator directly? :D
  10. Pin_Head
    Pin_Head
    13,736
    1,305
    Feb 6, 2002
    OC, CA
    Unless you get a lot of pleasure out of working metal, there is too much labor involved in fabricating one to want to take this project on when you can buy one for $30-40.
    Cut steel.
    Accurately locate and drill 7 holes.
    Mock up and tack weld.
    Finish weld.
    Clean and paint.
  11. PabloCruise
    PabloCruise SILVER Star
    15,127
    755
    Jun 3, 2004
    Northern Colorado
    Do they actually work?
    What do they save the t-case from?
  12. TUFFTORQ
    TUFFTORQ
    504
    Sep 18, 2004
    Who makes them and where can I find one for $30-$40? Specter has them for $110. Seems a bit pricey. :confused: Any ideas?
  13. nuclearlemon
    nuclearlemon not an addict Moderator
    15,588
    Media:
    87
    403
    Jan 30, 2003
    meh-ico, colorado
    they run across the top of the t case (bolted to the top cover) and have an arm that goes through the upper tcase mounting bolt...i see em on ebay from someone who makes/markets them for about $27 quite often....i think i paid $30 for mine a few years ago
  14. drohweder
    drohweder
    1,145
    1
    Oct 5, 2003
    Golden, CO
    Isn't this the same product offered by JT outfitters? That other link didn't work for me. Let me know if there are other vendors as I heard JT stole the idea from someone and I'd rather give the guy who came up with the idea my money.
    Dan
  15. LC_Hamma
    LC_Hamma The Anti-Leafer
    2,660
    6
    Nov 11, 2002
    Dallas, Georgia
    First pic is one of those cheapo dealios built from 1/8" plate you're probably referring to & may work without any problems. Second pic is John Pardi's tcase saver, constructed from 1/4" plate. You can see which one is on my Cruzah & which one is just hangin' around:
  16. Pin_Head
    Pin_Head
    13,736
    1,305
    Feb 6, 2002
    OC, CA
    You could always run them both. :flipoff2:
    John Pardi does make a nifty saver.
  17. dgangle
    dgangle total rice SILVER Star
    4,003
    6
    Nov 24, 2004
    Heart of Dixie
    Anyone with a link or contact info for the pardi plate?
  18. woody
    10,333
    Media:
    303
    1,089
    Jan 15, 2002
    Toquerville UT
    Pardi's is a nice piece, but holy cow, they aren't given away....
    I ran the topside-only saver on my t-case for many years, combined with a thick/solid skidplate that protects the entire case. Despite busted pinions, longfields, newfields, t-case shafts, and many other items, I never once cracked the t-case housing itself.
    The "savers" are designed to keep the weak-ish stock housings from breaking. Those "cheapo dealios" are IMO a great product, priced right, and a good solution.
    AGAIN - It is my opinion that the vast majority of t-case breakage is the result of pathetic skid plates, and not the result of horsepower/torque....you thwack a chunk of alum enuf times, and it will crack. The stock plate is pathetic. Build one custom.
  19. cruiser_guy
    cruiser_guy
    11,209
    22
    Jan 20, 2003
    Wherever the truck stops!!
    The link given earlier is out of date. I like the $30 price better than the $100+ price. Anyone have a new link?
  20. woody
    10,333
    Media:
    303
    1,089
    Jan 15, 2002
    Toquerville UT
    Don no longer makes his t-case savers, believe making your own or ordering thru JT-Outfiters is your only option at this time.
