Count me in for one.
Also guys where is the best location to put filler and drain plug?
A simple split collar machined to lock into the snap ring groove, as well as clamp onto the entire exposed surface of the shaft.
i did a fill plug at the top and a drain at the bottom.
when refilling only put the amount of oil in that is recommended.
as Cicak says, makes for a quick and easy oil change ... i know of VERY few people that ever check the oil let alone change it out.
Looking at producing a run of these... stainless or zinc plated (much less expensive)?
These are about 1 month out.
