@65swb45 , Mark, I'm going to be installing the power steering pump soon. Your mount is considerably wider than the pump. What do you recomend using to space it correctly? Thanks.
Wait, I thought this tub was solid?
Lol, there is no such thing as a 40 tub that doesn't have some rust, especially on the rear sill. I own a 69' and I ended up cutting off the entire rear tub from the "B" post back and replacing it with custom sheet metal and tube. The tub didn't look that bad at all from outward appearances but the darn thing literally started to fall apart when I began breaking the panel spot welds..Wait, I thought this tub was solid?
Thanks a ton, i was just looking at mine this morning and it doesnt need an entire wheel well but has a few spots right on the rib. PM me your paypal info and what you need out of them and Ill get it on the way.View attachment 1313933
A fellow mudder helped me out with these, I have a few left if you are interested.
That being said, this is a really quality frame-off, I love the attention to detail here and the loyalty to Toyota parts.
Starting to get serious about saginaw pump install(not in final position). I have an early rad. shroud at the powder coaters but it looks like im going to have to trim either one. Also got sick of moving the removable shield from the splash guard around the garage.
View attachment 1309488 View attachment 1309491 View attachment 1309493
Showoff! All the rest of us common folk have to anchor the adjuster bracket with a water pump bolt...and use the front of the pump!
