- Thread starter
- #361
The 555 TREs showed up today, Ihave heard how they rust pretty quickly so a quick clearcoat was applied. Because, I am using the 60 steering arms and the 40 TRE, Cruiser Outfitters was also able to supply adaptor shims.
That tool saves many broken knuckles
Thanks Jim, after comparing the FSM and my pic, my retaining clip is in upside down. The ends angle up if im seeing it correctly.Wait a minute! The retaining wire is not installed properly. The center tail goes into the hole from the outside. I'll try to get a pic.
Did you order those or bend them yourself?
Your 40 is looking good BTW!
Josh
Thanks, the caliper lines are OEM. Part numbers are in the pics above the caliper pic. @beno is a good source for them.
I did the rear axle line and the one that goes down the frame. Its not tough if you have a decent flaring tool.
Better hurry, my power steering box, center arm rebuild and drag link repair kits are due this Friday. In all seriousness, my dad and I have been collecting parts for over two years and are at about 16 months since getting the frame back from paint.Awesome my next parts order from Beno keeps growing!
I plan on doing the rear axle line and the one that runs down the frame tomorrow. Hopefully everything will go as planned, I have a lot of catching up to do!
Josh
