pandasfj
Hey J, does the front floor mat on the drivers side have the cut out for the foot rest on a 62? Thanks.
I've got an 87 FJ60....I removed the carpet as it was trashed. Looking for HD vinyl.... for the front two seats and rear seating area.(floorboard area)..mainly to serve as a heat barrier.... is this vinyl suitable for that purpose?
I don't plan to run carpet anymore due to river/creek crossings and potential damage / mildew from that. So just looking for a nice thick vinyl setup for the floorboard area , which hopefully will also serve as a heat barrier...I've got warm floorboards which in the winter is not an issue but in the summer...its another issue.
Thanks for this J. Just bought!Found the specs in my files on the Noico:
- Noico Liner closed-cell polyethylene foam is the best alternative to rubber foam such as Dynamat DynaLiner sound deadening. The price of 1 sqft product of similar characteristics is three times cheaper! Noise and heat insulation Noico Liner has an adhesive layer which makes it different from many cheap offers. Noico Liner very is a versatile insulation material with excellent thermal barrier properties. It is the best way to make the car cool and quiet! It's easy to cut and install !
- Noico Liner has the same characteristics and excellent noise insulator properties as rubber foam. It absolutely doesn't absorb water & has no odor unlike polyurethane foam. It has a very low weight, oil and petrol resistant.
- The material used is an excellent insulator! The sound deadener material allows you to deal with both, cold and the heat. This is especially important in hot climate areas. Well-insulated interior is a pledge of high comfort while in vehicle. Noico liner heat shield material will solve the problem of excessive heating if your car is equipped with a powerful engine and enhanced exhaust system. It is also easy to use Noico Liner as the hood insulation (hoodliner).
- The operating temperature of the material is the same as of the rubber foam such as DynaLiner - up to 212 degrees Fahrenheit. DO NOT use this product as heat shield for mufflers, catalytic converters, DPF and more. In this case, you need to use special materials designed for 900-3000 degrees F.
- Specifications: Self-adhesive foam sheets (closed cell PE foam); Nominal Thickness 1/6 "( 157 mil / 4mm); Nominal Roll Size 19.7x275.6 inch; Number of roll in the stack 1; Total coverage area of 37.5 sqft;
That weren't so bad.
What have you got extra?? I can use a 40 set and carpet, brown for hj61?? ThanksMonth turnaround and 9866+ miles
I'm very happy with the service/product I get from them.
Jason
