mcguirejohnson
Yes, the baffle is dead center, and maybe 6-7mm thick. Right under the center heat shield bolt.
...I do have stock gearing, witch over here is 3.7... Right now i'm sticking with that, since i'm going down to 255/85r16's which will be a 33.4x10 or so. It should improve my fuel expenses too Will be killer expensive to regear these cable locker diffs, well a tad pricier than open diffs.
I did find my leak today, put transfer in neutral, gear in 5th, tied up the clutch fan and set the hand throttle to 2000rpm!
Felt around for leaks, and i could feel a small push around the turbo manifold.
Loosened up the dump heat shield, and snugged the nuts up another 1/4 turn, DID THE TRICK!!
I will experiment a bit more with shimming the wastegate bracket tomorrow. i'll go for 1.1bar first, and see how that feels.
Ah okay that makes sense that you are getting better efficiency. Lower gears + bigger tires = lower rpms...
I have to have 37s at least once in my life so I am going to try them out, eventually I want to lower it with a 3 link setup and run 33s or so, but that is way down the line...
Good job on finding the boost leak! Could you post up a picture of where you are shimming the waste gate? Once I get gauges I will mess around with letting the old girl breath a little bit more.
Any noticeable difference in power from turning up the fuel and adding a little more boost? If I'm not mistaken they are set to 7psi stock and can stand up to 15 ish psi.
