I'm currently waiting for an aftermarket seat heater kit to hook up the BMW seat heaters. Really only need the harness, relay and switches from the kit. I don't plan on utilizing the heating elements in the kit. Will post up some install pictures of that when it comes in too.
Just figured I'd mention it to you as these seats are the BOMB! A massive improvement in comfort for the 60. Spent 4 hours in them today and had no fatigue whatsoever. They are a drastic improvement over the stock seats.
On a separate note, I recently installed a "heat-roller" (designed for controlling heated clothing on motorcycles) to control the heated elements in the BMW seats and it works like a charm. This allows for 0-100% application of heat control, not just hi or low. I'll post up a few pictures this week if anyone's interested.
Stosh
I have to agree, i love the seat upgrade! For others interested, i made my own brackets, as i wanted to keep the under seat heater on pass side.
If my GF was taller, i'd have to remove it, because the pass seat is about 1.5in higher than drivers. I might get the 62 heater and lower it...
But HEY @Stoshu I'm SO glad i found your posts about the seat heat, i'm trying to hook mine up, but i have no clue how they work.
I was preparing to trace down the original bmw seat switch (big black box that rests in bmw's console with 3-level switches)
but it seems you have found a better solution with the "heat-roller" ?!?!?
What pins on the seat connector did you hook up to, and what harness/switch/heater kit did you end up with?
This is how mine looks like under the seat.
P14 i use for ground
P13 i have 12v hooked up to use the seat motors and movement.
is P25 for seat heat power?
there is a small to the right of P24, maybe for the temp reader.
The two in the middle, no pin marking in the yellow area, maybe they are for the seat belt tensioner (which i removed)
