Find the fuse and relay box under the hood...forward of the gas vapor recirculation box, in back of the battery. Take a look at the parts location diagram on the cover. You'll notice the ACC relay is the middle relay in the row closest to the engine.
To get power to the outlets regardless of key position, simply remove the ACC relay. Make a short jumper (12 or 14ga) wire, strip each end and attach a 1/4" male Fast-On (flat tab) terminal on each end, and insert each end into the larger relay sockets.
SkyTim...check p2 of this thread, look for post #35 from RobRed...he brought up the issue that the 2004's are NOT the same as earlier hundy's. Ymmv, obviously.This is not the case on my 2004, so it must have changed somewhere along the line. There is no ACC relay in the engine compartment relay/fuse box (I checked). The 2004 service manual calls it out on the REAR side of the left hand cowl junction box inside the vehicle, where it is quite difficult to get to.
I'd be careful about putting a jumper in the relay socket as listed above without first determining which pins go to the relay contacts and which go to the relay coil power - short out the power pins and you will blow something upstream.
Tim
Tim
We haven't screwed with the CIG circuit in this thread other than to say it's completely separate from the ACC stuff
CIG indeed runs stuff but it's dead with key off. Purpose of the thread was to let you run low amp stuff knowing that you may drain your battery if you connect too much stuff for too long a time.
Fixable by adding a dropout relay that cuts power to ACC when the battery drains down to a voltage that you specify.
Steve
There is a single fuse between the relay output wire and the three outlets.It's possible, but isn't there still a fuse for those outlets in between the relay and the outlet? Some cigarette style plugs have fuses to protect the device.
Blown fuse?? You might want to check power between the terminals shorting the ACC relay contacts and ground.@RobRed followed the directions and jumped the correct terminals (I believe) but still no ACC power in the cab. What could be wrong?
