- Thread starter
- #21
In for a 13.5" Spot. What doyou think about utilizing two of the 2x2s as well, angling both out a bit for a bit better spread and cornering illumination.
Jon,
With that combination you will be adding 4,700 lumens to the front. That is going to increase your light output quite a lot. Pairing the 13.5" with two 2X2's angled outwards is going to give you a very wide angle. That setup is going to be able to penetrate 300ft+, while consuming 6.88amps they will still use less than your low beams and provide twice the amount of light. For the smaller light bars I recommend a spot beam.
