Alright folks, this is the beginning. Finally got all the parts for the build. Thanks to Lance at IronPigOffRoad for the super beefy yet simple spindle assy. The spring pin was about twice the size of what I was expecting from the picture . The latch came from McMaster Carr.
So the plan is to have this thing bolt up to the bumperette holes that most 40s have. The main bumper tube will stand-off the stock rear crossmember 1" by way of the mounting brackets. The tail lights will remain in the factory location and the bumper will be boxed around the lights. The strength at the spindle end is of concern once I remove that much material but with all the reinforcement and boxing I am confident that it will be as strong if not stronger than the solid tube itself. If not then I'll redesign it. The ends will be tapered as shown with the chalk, and the standard 3/4" clevis mounts will be welded through front and back of the bumper. I may incorporate a reciever tube below it with some tube work coming in from the sides to reinforce.
This particular one will use only one spindle and have only one swing arm that will extend the length of the bumper to which the cooler basket will attach to. The cooler basket will be a removable unit with angle iron that bolts to the swingarm.
One of the challenges to overcome is that it is essential to me to have the rear one side amby door still accessible with this whole unit installed (with cooler basket removed for day to day use). I am somewhat claustrophobic and I hate the idea of a passenger being trapped in the back due to a latch that's just out of reach. That and I also am lazy and when I want to drop off my kids at school I just want them to have to swing open the door and close it themselves . Therefore the swingarm will have to be within 1/4" of the main bumper to allow this clearance. It's doable but the spindle area will be difficult.
Havn't decided on the tire rack tube but I'm leaning towards a single 2x2 coming up from the swing arm as opposed to a 3 arm type of setup in order to reduce the weight load on the spindle.
The latch assy area is all just clamped on and a lot of the parts are not installed but it gets the idea across.
Hopefully this thread will help me get this thing going a little faster.
Comments please.
Comments please.
