Finally went to get my Rojo back and well , she was not quite ready . seems that she is leaking fuel from around the fuel primer pump now. I understand that this is common when pumping but is it supposed to stop leaking once primed ? I have read many threads on this issue and it seems many replace with the Bosch pump part. From my understanding this should fit right on along with the check value / spring mated on bottom. Correct ?
The shop said that the LSD might work better because it would have less slip, but at the sametime I dont want it to wear pre mature.
