Build Yeller Gold
Had our local club Xmas dinner last night, was lucky enough to come home with the big prize...going to need a rear power source now.
Antipig update...
Basement has started, what it looks like when an electrician does plumbing & framing.
And my dads latest project the girls named “Doris D” is getting close, we dragged it home almost 20 years ago now, that’s a 500cu 2 cyl.
More projects that don’t go “oink”
My girl (and I) spent the last month slowly getting her scouts racer together, race day was today and she did great, 3rd fastest and Best in Show.
Man I’m outta sorts with researching stuff, trying to see if this is a valid rear brake combination...he mentions a better proportional balance to front 60 calipers. I found where these are 43mm piston.
And using the first on-line bias calculator I found...it seems like not much front bias? :hmm:
@GRM any input?
@GRM any input?
Look at the surface area of the piston. It gives the story.
FJ60: 3.63in2
IFS Toyota (FJ60 upgrade calipers): 4.46in2
Mustang: 2.25in2
Monte Carlo: 4.91in2
FJ60: 3.63in2
Mustang: 2.25in2
Thanks for the input and detail pic on the source page, appreciated!
  • Like
Reactions: GRM
Small progress update - been a bit delayed with working on the new TT we bought for our big family trip this summer - which is probably not happening now.:(
Got after part of the front hangers today, my boy came out and was great to get some shop time in. I gotta thank Rush55 for messaging back n forth on ideas.
I have a couple lengths (I bought months ago) of 4” 3/16 bar I’m using for most of this, need to grab an appropriate drill for the 14mm pin still as I only have 1/2 and 9/16.
Layout, wd40 can is exact radius of stock hanger...
Showed my son how to cheat a hole bigger with running a hole saw in on angle, I only had 1 3/8”...stuff they don’t teach in shop class.
So as these spring hangers will be staying rear of front axle and they will hang a bit lower than stock hangers I’ll need to figure out a suitable height for the front shackle hangers next. :hmm:
Pig time tonight, roughed in a mini scab plate for the shackle hanger (yet to be built) and then tackled an ugly job.
I think this will be enough to spread the load from the shackle hanger, I’m open to comments before I weld them on.
Pass shock tower removal with the inner fender etc in the way was not much fun, my wife asked when I came in what I was beating on...she usually doesn’t hear much in the house from the shop unless I have the big door open.
Still need to dress it with the grinder.
So far, so good! Wait to tack if you can until you have your other pieces ready, then clamp them together to make sure it’s all square. Next I’d suggest spraying the frame and back side of the scab with some weld-through primer or high zinc primer. Mock your plate after it dries and mark the outline and sand off the paint just around the outline where you’re gonna weld it. Then for additional insurance, use that string measuring procedure to make sure they’re in line with each other on top of the measurements you’re already going off of.
Stay away from welding over Zinc 🤮. Not good for you!!
Should add a “Chlorinated Brake Cleaner” warning to this PSA.
