Build Work In Progress aka: Badass
Last cycle says 600 degrees, honestly not even sure my oven goes that high so I'm gonna risk not doing the third baking.
A self cleaning cycle goes about that high - but even I wouldn't do it for several reasons. It will finish curing in use.
Yes a piece of glass sheet is perfect to roll it on. If you only need one 2F pushrod I'm pretty sure someone on Mud can help you out.
Ah damn all you seasoned owners. It's bent.
Took a min or two for the brunette to overstep the blond... rolled them on the corner of the glass. All appear even except that number 4.
In Japan, four (四) can be read as "yon" (よん) or "shi" (し). The kanji for death is "shi" (死), which is why the number four is considered unlucky
Sorry, I had to......
There really is something different about you. Just saying...
If you call up classic cruisers, they should be able to get you a good used one.
I googled that name and came up with a bike parts supplier. found it... but I'll contact Georg at VH too, he "kinda" owes me a favor.
Cheap push rod inspection.
The shop that rebuilt the 3FE going into my FJ60 is rebuilding a couple of 2Fs for Classic Cruisers every month, so I'm sure they'll have what you need.
Heads ready! Going to pick her up!
So here she is in all her glory! I tell you I basically stared at it for an hour once I got it in the garage.
$324, basic valve job and head resurfaced. He primed it and replaced the ugly air line plugs as well. The spark plug holes look freshened too. Everything looks amazing.
I added painters tape to all the bare cast surfaces since I will add an enamel but I also might not get to it for a few days since my son is back w/ me now. I'll see about doing the galley plug as I picked up all the supplies the other day too.
The new valves look amazing too Jason @reevesci, thank you!!
Taped up.
