Just wanted to thank the 80 community for their continued support of
Window Rockets!
9 months of sales. Window Rockets are in every corner of the world. Window Rocket reliability has been excellent. Full transparency- There were 3 that went out early on with assembly defects. One had an actual defect in use after 3 months. All replaced immediately, analyzed upon return and process upgrades implemented to prevent future issues.
Approximately a dozen users have had trouble with install or poor/bad performance after install that I've worked through with them. I wanted to touch on these issues and put some troubleshooting information here.
I've gotten alot of praise for the simplicity and speed of install, but a few have had challenges with it. If the window rocket plug doesn't click right into place with gentle force DO NOT FORCE IT. Two things can be happening here-
1- The plug is upside down. Align the notch in the plug with the protruding key in the socket and try again.
2- Has your cruiser been through a full restoration or had very thorough sound deadening installed? Double check that the relay block under the kick panel hasn't been installed UPSIDE DOWN. Compare the orientation of the components with the pictures in the instructions.
Was your 80 series built in Venezuela? Before you install the Window Rocket, remove the old relay per the instructions and check the part number on the relay. It should be a Denso 90987-02004 or equivalent. If the part number is something else that does not cross over there's a good chance your 80 series was assembled using a relay with a different pinout. Contact me and I will walk you through re-pinning the plug so it works properly. This is also something we can do here before you purchase.
So you put the Window Rocket in and now your windows suck worse than they did before!??! Feel free to submit your page long obscenity filled email through the contact form on Powertrain-integration.com. Once you've done that, and you've received my heartfelt apology email, get your hands on a voltage testing meter with a good battery and I'll have you test voltages in two places, but here's the tricky part- I'll need you do it with a helper to run one of the windows while you test. Basically, we can determine if the Window Rocket is at fault here or if your vehicle's wiring is the culprit. So far, 8 out of 8 times, the vehicle wiring is the issue and I can help you with a fix for that- Everyone has been VERY satisfied with window function after some wiring mods, but I will also take the Window Rocket back if you aren't interested in modifying the wiring.
Thanks again!
Dustin
