- Joined
- Jan 4, 2014
- Threads
- 94
- Messages
- 3,042
- Location
- Little Rock, Arkansas
- Website
- www.facebook.com
- Thread starter
- #161
You got it........!![]()
Excellent! I thought so considering I couldnāt pull it back out but just wanted to make sure.
I have updated Post #108 with part numbers for all items that have been (or will be) replaced as a reference. CV is in, knuckle is on, lower & upper ball joints are torqued (no cotter pins just yet but donāt worry they will be on there at the end), and steering arm is torqued. Tomorrow Iām going to raise the LCA to ride height to torque those bolts, then bolt the torsion anchor arm on, bolt newly turned rotor to the hub and repack bearings, reinstall hub/rotor and set preload, reconnect ABS harness, torque sway bar and lower shock mount, and hopefully wrap up but weāll see. Gotta wait on FedEx to deliver my last package of parts from Partsouq! One of the window trim pieces was bent so they had to order another so that plus memorial weekend delayed shipment a little but no worries.
