- Thread starter
- #41
I'm not sure I get the jist of this. Factory FL replacements are available at this time, and a boonie get-out-to-civilization (... and I'm using this term rather loosely when it comes to the US these days...) fix for when no spare is available isn't that much out of this world.
And it's the same with regular fuses: just replacing a fuse with a new one in case of a failure might not go very far without determining the cause of the failure - FLs aren't much different in that regard.
If anyone feels the need to re-engineer ths FLs - fine, go ahead, perhaps you would care to provide the proper numbers that serve as the basis for the newfangled gizmo. Hell, this has worked for bumpers without worrying But any numbers etc. - so, let's go ahead...
Other than that, keep in mind that the best backup solution for unexpected breakdowns is simply a having a second truck.
That's fine, if you just accept everything "as is"..... more power to you. But, I like to figure things out, and build things better. Hell, why didn't we just keep the model T? It worked, and served the purpose! Right? As far as spares "simply having a second truck" makes no sense at all. I don't run in your local heep clubs. Or down in the sand pits with Rocko, Huck, and Cooter! I run East to West, North to South. When I hit an ocean you either load it up, or turn around! Hell, I'm 50, and have been retired from the Corps since 2007, so I have nothing but time to explore. That is why I need a better solution than "just carry 10 spares" or "have Cooter follow you in a spare". Who's paying Cooters way? Doesn't make very good financial sense.... does it? There are sheep, and there are wolves, choose which one you want to be.
