What have you done to your Land Cruiser this week?
Finished pulling all the loose parts from the frame and tub. Big batch to sand blast later this week after inventory.
Pulling tub sometime next week?
img_1136-jpg.1730723
Pleasant surprises are ALWAYS welcome
Since it is hotter than the surface of the sun in Tucson, I decided to do some summer maintenance in advance of the fall trail runs. I pulled the valve cover to try and locate what I thought was the sound of valve lifters knocking but instead found no noise once the cover was removed. I decided to polish up the cover.....i do not see that the bolts need to be torqued ... is that the case?
Also pulled all four wheels and found that my front disc brake retainer clip was mangled - replaced it with a nice new one.
Cheers from SW Montana:cheers: Cool, unique rig!
I need to see more on this!
Do you have a build thread or at least some more info and pics?!
Looks sick!
No build thread.
My work is at best B+,
Not worthy of this forum.
I had several parts rigs in back that I put together. 66 FJ45 basket case I bought in pieces, no bed, 78 fj40, 81 FJ60, 69 FJ55.
Took parts off each.
I was inspired by Whitey with the smaller dropside bed.
Used this forum as a instruction manual on “How-to”each phase.
I’ll attach a few pics,
Currently using doors off my 40
@jm599 did you use the 60 axles under the 45? Very nice rig sir! Certainly worthy of this forum. We definitely need more pictures and build specs.
We don need noh stinkin doors!
Had these half doors for years... Finaly using them...
I did keep a list, for my kids, should info be needed in future:
66 FJ45 Reference Notes
Parts used in restoration
66 FJ66 cab and frame sandblasted,
Triple epoxy primed
monstaliner to floor/firewall both sides
New windshield
New corner windows
New rear slider window
78 FJ40
Wiring harness, refitted/deleted smog & added trailer plug
Windshield frame with wipers on bottom
Rebuilt Transmission/Transfer&ebrake
78 firewall grafted in on drivers side for Racer brake booster
81 FJ60
2F engine/new OEMpower steering-pump 50amp alternator -
complete rebuild/head- shaved .030. Valve grind
de-smog w JimC idler
Intake under carb built up alum weld
racer double circuit power brakes
New clutch system
New aluminum radiator / hoses
Weep hole in head tapped & plugged
Exhaust stainless flex joints/resonator
78 small cap electronic dizzy
Oil pressure warning light
Steering
Column-
fj55 inner w u joint,78 fj40outer tube
Intermediate shaft to box from inside fj60 column (is collapsible)
Fj60 power steering box & Pittman
Steering column inset towards cluster 1”
FJ60 axles complete rebuild w ARB Air lockers 4:10 ratio
Kept rear ebrake, handbrake behind seat
Alcan 4” lift 55 Springs, 1” added to shackle ends, 500 lb extra load custom
New greasable pins/longer shackles
New custom driveshafts
Original seat raised 2”
Tranny shifter altered to clear safe
Odyssey battery
Roll bar to frame/Gr 8 1/2” bolts
Trailer hitch 7way/4way plugs
LED taillights
Racer LED headlights
Monstaliner inner roof
New 3way seatbelts
Racer Fuji carb
Mitsubishi dropside mini truckbed
6 degree pinion angle shims
Schwab measured 3.4 degree positive caster
Most of these ideas came from this forum, I would have been clueless without it.
Upgraded the headlights finally. Also got some new hood latches. Now I won't be embarrassed when I'm checking the oil at the gas station cutting zip ties. Also got my Apron emblems in, hopefully now people will stop telling me how nice my "Jeep" is...
