Annual run across Stateline for fireworks. Ethel all set for SAS8 here in a few weeks
Happy 4th.
Let me know if you find the suitable replacement for our early 40's. The newer units have a different bolt pattern.Ran out of gas….time to get a replacement fuel sending unit….mine isn’t working.
if your stuck.. Cuiserteq etc can't supply... Try 4x4World.com.au... they've been really good for my specific HJ47 parts... or megazip.netLet me know if you find the suitable replacement for our early 40's. The newer units have a different bolt pattern.
Mine has also crapped out, precipitating to a near pants-crapping in Death Valley!
So the research that I’ve done…Toyota part 83320-35020 will work (same ohms for empty/full, etc). You will need the gasket as well. City Racer has a fuel sending unit and it is labeled for 66-72, but I messaged them and they said it would work. I’ve also read the mounting plate might need to be amended, as you mentioned…but haven’t found out ‘how’ anyone has done that. I’m picking one up this week from a fellow Mudder and hopefully get it figured out within the next week or so.Let me know if you find the suitable replacement for our early 40's. The newer units have a different bolt pattern.
I made it from a scrap of 1/4 by 6 strap.Yo... where'd you get that plate? I was going to make one, but I wasn't sure if they were available somewhere.
I believe the way you have it is correct but can’t be 100% sure. I would google some images and see what you find. I bought some new in the past and bought one at a time so if I can a picture I’ll see if it’s correct.My bumperettes were black and I found a nice pewter substitute…painted and clear coated …on re-install, I noticed the shape. I would see advertisements showing the left bumper at or the right bumper at, and I always believed they were both shaped to be square until I took them off and tried to put them back on… one edge is swept more on the curve…does this curve go on the outside edge or the inside edge.?
These are on the outside…seems to provide better view of the backup lamps??
Installed a drop down tail gate from a 1972 Fj40 onto my 1980 body off restore. Working on the body receiver for both latches and will move the license plate mounting bracket over to the right side and fill holes. Also adding brackets to the inside for factory soft top bows.
Here you go!I believe the way you have it is correct but can’t be 100% sure. I would google some images and see what you find. I bought some new in the past and bought one at a time so if I can a picture I’ll see if it’s correct.
