Looks great!!This was my third attemp, the first two were utter failures. After bending the brake lines it seemed like this, only a handful of 90° bends, would be so easy
Looks great. Have you tried to install the air intake housing?This was my third attemp, the first two were utter failures. After bending the brake lines it seemed like this, only a handful of 90° bends, would be so easy
Don't they make a flexible stainless steel line? That would make it 100% easier?@steffan You did a great job installing this hardline for fuel. They are so much heavier then brake 3/16. Complex curves are difficult to configure. I tried it stainless. I tried it in steel and finally had to switch to copper nickel and….. even then it kicked my ass. I’m still not happy but the truck is running well. I have about 9 feet left to give it 2 more tries.
You did really well…I am looking for that holding bracket that you have at 90 degrees in front by the t-stat as well.
That sucksTook it to the dunes and added a new hole to the rear diff cover. Even with the hole it made it back to the trailer. View attachment 3635519View attachment 3635520View attachment 3635546
I look at is a fun project to figure out how to upgrade it. LolThat sucks
The latent heat of vaporization of gasoline is lower than engine temp of 200 degrees.@charliemeyer007 Wait a minute….. fill me in on vapor lock and hard lines…? Are you saying the electric fuel pump eliminates this issue…all unfamiliar territory for me
Metal line conduct heat both by conduction and IR, rubber lines are insulators. My electric fuel pump in under the battery. The hose runs up over the engine to the carb - shorter path so fuel has less time in the line to absorb heat, besides being in an insulated hose.
Back in the 70's I dated a lady with 66 something V8. Someone had used like 3/8 copper line for the fuel. It would vapor lock at the drop of a hat on a hot day. I split some old fuel/vacuum hose lengthwise and covered the copper line. It never VL after that.
forum.ih8mud.com
