Green Bean
Nice, where did you find that or get it?Installed a different shift instruction plaque to more accurately reflect 4-speed with vacuum actuated 4WD and under-the-dash Hi/Lo shift. Thank you to @shipmag for making these and the great buying experience.
Nice work. Wish you were my neighbor !Repaired a ‘tear’ in the drivers front fender. Used JB Weld as a filler and found a great Rustoleum color match for the final coat. Much better than the Robins Egg Blue the PO deemed acceptable.
Thanks but It only looks great from about 5’ away. Which was my goal.Nice work. Wish you were my neighbor !![]()
I feel like you could probably start a whole thread just about getting wood in a 40.Picked up some free wood courtesy of NGrid. Drove it a bit to see how it handled fully loaded.
I used that fluid in my 40 last time I serviced the transmission.Been working more around the house after 4 months of neglect …on the other hand, this showed up today
Did you go to Jeep Day at Crystal Beach? I saw on the news the residents are extremely pissed off there.
No, I stayed away from there. We went to Sunny Beach on the island, plenty of other rigs there too. I live here on the island.Did you go to Jeep Day at Crystal Beach? I saw on the news the residents are extremely pissed off there.
forum.ih8mud.com
beautiful!got some brake lines bent up and flared - much to my amazement, no leaks
Do you have the hose clamp part numbers? My next-ish task is to replace all the cooling hoses.Dressed up under the hood: Replaced solid band stainless hose clamps with OE double wire ones (still available from Toyota). (On a side note, I was recently under the hood of our Lexus and noticed that they still use the same clamps). This seemingly simple project hit a hiccup when one of the inlet nipples on the rear heater broke off and puked fresh new coolant all over the place. Sourced a backup rear heater core while I mailed off the original for repair. The “while your in there” list included replacing the upper and lower thermostat housings with OE (still available from dealer); new OE upper & lower T-Stat housing bolts; new OE thermostat & gaskets; heater shutoff valve (@ToyotaMatt); a shiny rocker cover from Nate (@mattressking), OE rocker cover gasket and a OE firewall heater hose bracket from Dallas (@dmaddox) and hard fuel line brackets from Paul (@Ackcruisers). Also, added a couple of M6 nutserts at firewall to accommodate screws for heater hose shield at front passenger footwell. Also, replaced plug and coil wires with OE. Burped her with the burping funnel and put her to bed. Thank you Matt, Nate, Dallas and Paul.
OEM TOYOTA HOSE CLAMPS for 1970 FJ40Do you have the hose clamp part numbers? My next-ish task is to replace all the cooling hoses.
Looks like you replaced your water pump pressure tank for your house. Every bit as neat and tidy as your Sniper project.@Green Bean big undertaking with seemingly routine maintenance parts…this is a great feeling of accomplishment in my book and inspires longevity for your FJ40 each time you start it up…![]()
I was really looking forward to doing some Land Cruisey things like the MT-90 trans fluid and my @shipmag hose…. but had a side track today…
My wife said “. Make believe it’s the FJ40”. …
