Ackcruisers
This should be a poster with caption that says “BAD ASS”. The bow makes it perfect.View attachment 2990736
Been daily driving it since bringing it over from Anchorage.
Assembled T-case direct shifter and test fit.
I just reinstalled mine too, but yours is a lot cleaner than mine.![]()
Well, it was all fun and games until now.
I parked the cruiser for 30 minutes and when I returned there was oil dripping from the timing gear cover(so I think). I tried to tighten the 2 lower bolts and just made things worse.
Here's a piece of cardboard after a minute of being place under the drip
Its frustrating, as I've replaced the gasket multiple times now. This latest SNAFU happened about 1,000 miles after replacing the gasket.
Not sure what I'm doing wrong.
I used the FIPG on both sides of the gasket, just like when I did the oil pan.
Its been suggested that I only use the FIPG. That the gasket is not necessary if using the FIPG. I am inclined to try it. Any insight from those who have gone through this?
My oil pan gasket was similar. It leaked horribly for a few days then after a few cycles of driving it stopped. The cork expands as it absorbs oil. But you can overnighten it to. I would run it for a week or two and see if it stops.Well, it was all fun and games until now.
Only show up if you bring the Mule.This has got to be frustrating.
These cork gaskets are fragile. You can actually over-tighten a cork gasket. If it's compromised in anyway (small tear) you'll only exacerbate the problem. Over-tightening can flatten the gasket and cause weeping at the point of compromise. The cover is only tightened enough to secure the cover without crushing the gasket. I think, but don't recall right off hand that the fasteners/bolts have a specific length and location also. I think they are 6mm and 10mm. Make sure your timing cover surface is flat and clean. Lastly, the sealant isn't the culprit. Apply it, add the cover and give it a chance to dry a day or so before you tighten the cover all the way.
If that doesn't work, I'm willing to drive up during moose season and take photo's for the visual record..![]()
Sorry for the confusion. The oil pan gasket is fine. Hasn't leaked since I replaced it in 2020.My oil pan gasket was similar. It leaked horribly for a few days then after a few cycles of driving it stopped. The cork expands as it absorbs oil. But you can overnighten it to. I would run it for a week or two and see if it stops.
Brother, I'd be honored to tote the Mule to your neck of the woods, trouble is, I may not come back to WV.....Only show up if you bring the Mule.
I'm aware of the bolt size(s) and orientation. I'll definitely let the FIPG sit for a night before tightening things down.
Thanks for the advice.
Have you recently adjusted or tightened the oil squirter in the plate?Well, it was all fun and games until now.
No. I never touched that thing. While researching this topic, I read about that squirter and the headache it can cause if not adjust correctly. Thanks for asking.Have you recently adjusted or tightened the oil squirter in the plate?
some door work... rust cleaning.. rust converter .. welding..
View attachment 2990160View attachment 2990162
View attachment 2990167View attachment 2990168
