What have you done to your Land Cruiser this week?
I started my FJ40 project. The beginning of the year down. Took off the spare tire and bracket, and the rear doors. Must rustier than thought. I had thought about naming it Big Bird since it was originally Mustard yellow, but now it might the Yellow Submarine since it looks like it was stored in the ocean.
@Living in the Past @KingAir Driver
We used Strapworks D-ring with clip (1") (SSDRC) and stainless steel loops (1") (SSL). We removed the D-rings from the clips and replaced them with the loops.
The material is authentic canvas duck, same dimensions as OEM. You can see that the loose end is sewn into a point, replicating OEM. This acts like an aglet on a shoelace, to simplify poking the end through the D rings.
My :princess: came through with some "prototype" sewing:
Cotton duck webbing (OEM style) stainless clamps and rings, heavy duty braided polyester thread:
We made the "threading" strap 2 inches longer, since I have a repro "old style" tool roll:
And easily handles the later version:
Starting the cleaning process of the interior.
buckets of mud water.
Got the key loose and out. Also got the ignition switch operable.
Noticed the motor mounts are broken!
as well as the trans mounts.
All in all it was a good day of vacuuming and cleaning thick dirt.
are those wood blocks with a band clamp on the 3 on the tree? and is that a lava flow in the engine compartment?
and a custom dash pad with the band clamp?
Yes it is a block and band clamp on the tree post.
Don’t know the reasoning.
I am converting it to a 4 speed.
engine bay is mud real.
Yes dash pad seems to be covered over.
it is actually well done.
those things aren’t important to me yet.
getting it started and running and stopping is my main concern for now!
then I will get into the interior.
DUI installed last night 😬
Hey Slapmak
So I looked Into that block and band clamp.
it looks like it is being used as an alignment block to keep the rod straight. Maybe from binding. That could mean the linkages are worn and they bind.
just a guess!.
Haven’t had much time to work on mine lately but today I was able to paint the roof cap and bezel (yes it’s upside down…). Had to do it outside and got a couple bugs but tweezed them out and I think they turned out great!
Small stuff for the '73. Installed FJ60 plug wires to accompany the FJ60 distributor. I think it took longer to order the wires than install them. Pressing the boots to the plugs and distributor cap was a reminder of how well OEM stuff works for the application. This engine had some generic loose fitting wires that I yanked and sent to the trash. View attachment 2695345View attachment 2695347
Heard about this on the 60 series forum for washing out frame rails. This is a hose with fittings designed to clear plugs in plumbing, just hook it up to a pressure washer. It came with two spray heads, a button style and a rotating style. I found the rotating head to work best. Messy job but the inside of the frame rails are cleaned out.
I wish I had realized how much dirt/mud was built up in our 71’s rails before rolling it in the shop and yanking all the brakes and axles. Ugg. I step forward, two steps back.
